Hi,
Been cleaning the carbs on the '79F, which came with the series 3 instead of the originals, and found that the idle mixture screw on carb #2 is nearly impossible to remove. I've soaked with PB Blaster, Liquid Wrench, you name it, from both sides and have been able to back it out to about 1/4" from the top of the tube. But the screwdriver slot is about to give it up and I don't want to do more damage to it before getting suggestions.
It make me work quite hard for the progress so far. And contrary to what you would expect, it would not screw back down more that 1 to 1 1/2 turns before binding again. I was expecting to be able to screw it back down along the "progress route" but it would have none of it. I think it was cross-threaded in and thus the current situation.
btw - these are the dirtiest carbs I've ever encountered.
Any one run into this situation?
I'm considering cutting the top 1/4" to 1/2" off the "tower" it screws into to get access to it with a pair of small vice grips. I did some comparisons with the other "towers" and noticed that this would not compromise the threads. The head slot is now almost gone too. I would need to grind down a screwdriver to attain proper hold on the head, no big deal but it's not giving it up!!
Should I just drill it out and replace it? Are they available?
Any and all ideas are welcome.
Thanks
Thanks
) and after a little coaxing it came right out. Hip, hip, hurray!!!
