I did not dunk anything, as I don't have a dunk tank. I do wish I had an ultrasonic cleaner, but that will have to wait a while. I have read in several other threads that dunking carbs will destroy the butterfly seals. Is that what you are referring to? I am hoping that I don't have to deal with that issue.
The old idle needle screws all came out very nicely. No tips left in the holes. I screwed the new ones all the way in and saw the tips of each as they emerged into the carb body. I then backed them out 2.5 turns. That's the default setting, isn't it?
I will pull the carbs again (getting good at that) and put the o-rings in. Thanks for that info. If the spark plug has black stuff on it, does that make it fouled? In past experience with plugs, I could always just take a wire brush to them and clean them up as long as there was no carbon traces on them. Is that not true here?
