I know that some people on the board have used a few different methods to control handle bar vibration including filling the handle bars with spray-able expanding foam.
I was wondering what you all think about this ...
Because my hop-up bikes engine will be mounted to the frame with solid alloy engine mounts, I was thinking that perhaps after the wielding is done, that I might drill some small holes in the frame tubes and fill the frame tubes with spray-able expanding foam. If the holes are placed in a fashion that they themselves would not weaken the frame would doing this reduce vibration? If it works on the handle bars do you think it would also work on the frame?
Rob
Rob
