spark plug gap
  • alabama-al
    • Nov 2006
    • 35
    • Dadeville Alabama
    spark plug gap
    Can't find my manual, and I don't remember. What is the proper gap on the standard xs1100?
  • Axel
    • May 2007
    • 869
    • Renfrew,Ontario
    plugs
    .032 I think
    XJ1100K
    Avon rubber
    MikesXS black coils
    Iridium plugs w/ 1k caps
    MikesXS front master
    Loud Horns (Stebel/Fiamm)
    Progressive fork springs
    CIBIE headlight reflector
    YICS Eliminator
    • Axel
      • May 2007
      • 869
      • Renfrew,Ontario
      Clymer
      Clymer manual says .028 to .032 with a wire feeler guage
      XJ1100K
      Avon rubber
      MikesXS black coils
      YICS Eliminator
      • lvrsnr
        • 114
        • Kelso, Washington
        0.028" to 0.032"
        Alias Larry R in Kelso WA
        When in dought, punch it.
        XS1100LG Precious current
        XS1100SF Ruby gone to a better home
        KZ900B MIA stolen (ALL bike thieves MUST GET OFF THE PLANET more politically correct ???)
          • 8870
          plug gaps
          If you run hot coils, such as Accel, open 'em up a bit more, like .035-.040.
          The more voltage the coil is producing, means the spark can jump a further gap. Bigger the gap and spark, the better igniting of the fuel vapor.
          • randy
            • Dec 2003
            • 4521
            Anyone up for a 'spark' thread? My experienced opinion:
            There is only one spark, once the fuel is lit, it's lit. No matter how 'HOT' the spark is.
              • 8870
              I thought there is weak spark and good spark. Then there is also pretty good spark. Bike runs cr@py with gaps too close, but if your coils are weak, then it helps.
              • TADracer
                • 1417
                • Kenner, Louisiana USA
                Here is my long and short...mostly short
                Its not just the spark or the resulting flame but it is the quality of the spark and flame. There is literally tons of reading on this subject. Voltage requirements, spark kernel, baromnetric pressure, heat range, ignition timing, chamber aerodynamics, fuel/air ratio, piston shape, and on and on. Makes you want to think twice about changing your plugs.
                In short though it takes heat and pressure to ignite the fuel/air mixture, even in a diesel (in a deisel it is done with high compression). The spark provides this heat and pressure in a gasoline engine and involves everything up the line from the tip of the plug to make it happen optimally.
                Opening up the gap on even a stock ignition will give a bigger spark but will put alot of added wear and pressure on the wires, coils, etc. Having a more powerful ignition system is why it is easier to open the gap and still develope a strong spark kernel that is so impotant to lighting off the fuel evenly for the best flame front and fuel burn.
                Then there is spark plug design and how much the spark is shrouded (just like the recent thread on unshrouding the valves). Exotic center electrodes and ground strap shapes and designs add to the mix of what kind of spark you get. An exotic and small diameter center electrode will take less electrical energy to produce the spark and thats why platinum plugs are so popular. With a standard type ground strap the spark wants to develop in a cone from the center electrode to the outside edges of the strap providing an unshrouded spark. The U groove type plug makes the spark want to jump to the center of the ground strap thereby making the spark more shrouded and possibly less effective in some motors. Then there are the split point plugs that do what the standard ground strap does but twice.
                All these things can make one plug perform great in any given motor and lousey in another. Since I am certainly no electrical/thermal engineer, it boils down to trial and error for me. Now over the years I have tried several types, styles, heat ranges of plugs and I find that I always go back to the NGK BP-6ES (or BP-5ES in Winter) non-resistor plugs that some Japanese engineer obviously ran tons of calculations on. Go figure! Still, this is a very interesting subject.
                Mike Giroir
                79 XS-1100 Special
                • prometheus578
                  XS-XJ Super Guru (RESIGNED)
                  • Aug 2004
                  • 4012
                  • Olympia , Wa.
                  Of course, TRBIG is gonna sing again because I posted links...
                  ... and didn't take the time to rewrite this all in my own words.
                  http://www.dragstuff.com/techarticle...ead-plugs.html
                  So... there is everything that anybody needs/wants to know about spark plugs.
                  In my mind, there are three types of "spark plug" people.
                  People who really don't care about all this...
                  People like me who buy the correct plug and just put them in...
                  People like TRBIG who want the best performance out of their bike, though they only use it to ride to Walmart to buy beef jerky and tube socks.
                  Oh yeah, I forgot about "indexing":
