Happy Spring, all,
I'm rebuidling my carbs on my 78XS E, all new jets and such. All the parts I got match the old ones except the valve for the floats. The new ones have a lot less spring to it and brings the float hight way to high (low when upsidedown) I would need to adjust the tang alot to reach the desired 25.7mm (about 1") height. should I just use the old ones, they're on the money. My hesitation is that the main reason I am rebuilding the carbs is because #1 was leaking. I'm doing the petcocks too.
Also, I read on the forum somewhere that the floats should sit over 1/2 way out of a cup of gas when checking for buoyancy. All 4 of my brass floats sit only a about 1/5 out of the gas, with no sign of pin hole leaks. Is this ok?
I want to get everything back together today, fire it up and fine tune it. Any help would be great...Thanks...Phil
