I knew things were going to good. I got the front brakes sorted out. Decided to clean upt he rear Caliper for good measure. Had trouble getting the pad screw out, but finally got it, using brake MC to push the piston out and ran out of fluid. Now the rear MC will not pump fluid for nothing, I pulled the banjo off the caliper and pump the MC you can hear it push and gugrle but no fluid. Tried opening the bleed bolt, pulled the MC apart and put it back to gether everything seems tight, twist and push to get the seals in, and can hear it pumping air and gurgling, but no fluid moving.
Need new seals in the MC? Is there a trick to getting this thing bled??
Any help would be appreciated.
Thanks,
Thanks,
