fork oil for a 79 xs11oo
  • JOEY
    • Jun 2008
    • 73
    • Hastings,Fl
    How much oil goes in each fork for a 79 xs1100 and what kind of oil?
    It is better to stay silent and be thought a fool, than to open one’s mouth and remove all doubt.
    10W fork oil. 212cc per leg.
    • JOEY
      • Jun 2008
      • 73
      • Hastings,Fl
      Thanks bikerphil.
      • TADracer
        • 1417
        • Kenner, Louisiana USA
        You dont say if you have a standard or a special. Like bikerphil says, 212cc of 10w fork oil if you have a standard. If you have a special it is 225cc and then some air on top of that through the shraeder valves on top of the fork. About 15psi is about normal and 21psi is for max load. No more than 36psi or you could cause fork seal damage.
        Mike Giroir
        79 XS-1100 Special
