oil pan bolt stripped
  • joebus
    • 104
    • Indianapolis
    OK well it is not the oil pan bolt but the pan it self. I was changing the oil to get it ready to store for the season and when i took of the bolt there was metal wrapped around the bolt Now i am having a hard time getting the bolt on there real tight. with my finger i can feel that the threads go back further then the bolt actually goes. So does that mean i could just get a longer bolt? any help would be awesome
    1979 XS1100 SF
    1981 KZ440 bobber
  • Ivan
    • Jul 2008
    • 2524
    • Hutchinson KS
    You might drop andreasweiss a pm to see how much a used pan is.
    A longer bolt may hold for a while, but in the end you are putting a steel bolt in an aluminum pan and you'll need all the thread you can get.
    Another option would be a helicoil, or a keensert to repair the threads.
    It is my humble but accurate opinion that the oversized oil plugs they sell at pats stores are a joke. Supposedly they cut new threads, but I have replaced many engines on the sole account of these dastardly inventions. Don't get me started on emergency battery cable ends either.
    Ich habe dich nicht gefragt.
    • tarzan
      • 1700
      • Chandler,Az.
      Yes you can use a longer bolt if it has enough thread to hold it.Otherwise you can helicoil it.
      80 SG XS1100
      14 Victory Cross Country
      • joebus
        • 104
        • Indianapolis
        bike bandit has the oil pan new for 135ish... Is there any place cheaper?
        1979 XS1100 SF
        1981 KZ440 bobber
          oil pan
          I've gone the longer bolt approach before and it didn't work out the greatest. Try member andreas or eBay... HTH
          http://cgi.ebay.com/ebaymotors/1979-...Q5fAccessories
            How about just tapping it out to the next closest size standard thread drain plug? You may not even have to drill the hole out, the stripped out threads in the pan may be a big enough hole to run the tap into.
              Autoparts stores carry oversized drain plugs. I used one in a pan for a long time. No need to even tap it.. it threads itself. I used a metric one, but since you're re-threading it, it really doesn't matter as long as it's big enough to get a hold of some meat on the pan.
              • andreashweiss
                • 951
                oil pan
                I have a good used oil pan for you, please use the private message system to reply to me please. thanx andreas
