I got the seat back today from B & H Specialties and it looks great!
After a nice summer of riding, ol' Columbo started to run like the carbs needed some TLC and the new iridium plugs were running a tad on the lean side. I bought some new, larger, main jets and dug into the carbs for the first time since the beginning of summer, before the Yosemite rally.
It's been fun!
Thanks to the extended tour through the carburetors' casting numbers, needle jets, jet needles and just general jetting - compliments of and my personal condolences to Crazcnuk - I tore into the carbs with a new vision and a much better idea of what type of parts really ought to be inside of a bank of 1980 XS1100G Standard carbs.
Okay, I was wrong!
Now I can't find any carb body casting numbers to help me identify the carbs. Where, exactly, on the carb body casting is the part number? The only place I haven't been able to look is underneath the carburetor rails that hold the carbs together in one bank and those screws are screwed quite firmly in place.
According to the Yamaha factory manual these carbs are set up like a 1980 Special with #110 mains all the way across and 5GL16 jet needles instead of 5IZ7 needles. I didn't spot the #110 jets on the #2 and #3 carbs when I cleaned them up because the main jet faces and markings were almost completely obliterated by corrosion but the jet orifices themselves cleaned up and work fine.
I used someone's tip of polishing the brass jets, the tubes and the the needles until they look like shiny new parts. I finally managed to find a part number on the needle jets (emulsion tubes) but I've never seen the part number:
(Mikuni logo)300FJX-2
Yes, it's all run together like that with the leading Mikuni logo. They're supposed to be 300 X-2 jets but I don't know if the FJ in the part number is significant or not.
Needle jet (close-up under magnifying glass) cleaning lower row of large air bleed holes
XS1100G needle jet (close-up under magnifying glass) cleaning upper row of small air bleed holes
The needle jet orifices are not worn
Needle jet and main jet cleaned and polished
The new main jets I picked up originally to try to go up from the #110s in the #1 and #4 carbs are: 2 ea #115, 2 ea #117.5
After finding the #110 mains in #2 and #3 carbs I bought 2 ea #120 mains but I did not know at that time that I had the 'wrong' jet needles.
I put the #120s and #117.5s in the carbs and installed the bank of carbs. The bike started up and ran fine cold but the carbs are way out of tune and it's too late at night to do anything but shut down and pick it up where I left off tomorrow!
Regards,
Scott
It's been fun!
Okay, I was wrong!
Regards,
Scott
