FJ-1100= 96 Horsepower & 61 ft. lbs. Of Torque
A box stock FJ-1100 was making 96-98 horsepower at the rear wheel and 61 ft. lbs. of torque and the 1200 was making about 5 horsepower more vs a stock XS-1100 which was putting down about 70-75. There are at least 3 people on here who made low to mid 90's with the XS me being one of them and it wasn't nearly as diffulcult as putting an FJ motor into the XS and I have seen more than a couple of these conversions over the last 20 years. Of course the FJ motor has a lot more potential than an XS and it's cylinder bore centers are wider than the XS and with sleeves can achieve 1400 plus cc's versus about 1300 for a sleeved XS but you were I believe talking about a stock FJ. An Eleven with a Wiseco kit, properly ported heads, a good Kerker or Super/Trapp header, a set of MegaCycle or Web hard weld cams and properly jetted stock carbs with a modified air box will make 96 plus horsepower and 72 ft. lbs. of torque. You can fetch another 2% by cutting the head .020. Maximan made esentially the same power as I did with an unported head cut .028 but he used the 36 mm carbs from an FJ and the 1196 kit whereas I used the stock carbs and the 1179 kit. People also forget that when you start putting stand up windshields on their Elevens they are killing the top end. In the mid eighties Cycle-World did some test on a V-65 Honda Magna and found that there was a difference of over 5 MPH on the top end simply by the rider sitting upright vs leaning over. A stock FJ is much better aerodynamically than a stock XS in naked form and the XS with anything larger than a fly screen type windshield is a dead player at much over 125 mph. A sharp early model FJ would pull red line in high gear which was 145 mph. In 90, Yamaha changed the sprocket tooth count and the over all gear ratio got higher and they got slower acceleration wise even though they had a bigger motor and more power. You can gusset the frame of an XS and use V-Max type rear shocks and with a fork brace and sticky tires it's a decent handler but it's not a 900 Ninja in the handling department and never will be. The rear of an XS wants to rise when you throw the coals to it and you need a shock that is stiffer on extension to control this however stiffer shocks will be harder on your tail bone so you decide what you want. You can equal the power of a stock FJ-1100 and it will get it on in a straight line but it's got a skinny fork and the wrong amount of trail for a sport bike. An FJ weighs 536 pounds dry vs an 81 1100 Special which weighs 557 pounds dry. The bottom line is, a stock 70 horse XS is a dog compared to a stock FJ-1100 but that dog can be turned into a "Teufel Hunden" and you members of the USMC might recognise the name of that very special breed of dog. Like all things though, there is more than one way to breed a "Teufel Hunden". Stand back non believers, the've fired their welders and anything can happen!
Originally posted by xschop
View Post
