Vetter fairing mount
  • jeffe
    • Oct 2004
    • 393
    • Westerville,Ohio
    Was wondering if anyone has the mount for a Vetter fairing that theydon't need.. It would be for a 78 standard. Mine is slightly bent and I am not sure that is really the correct one. It seems to mount lower than it should. The gauge cluster seems to be to high. I have access to Cyclesound unit, but it won't fit because the gauges are in the way. If nothing else could someone post some pictures of a correctly mounted Vetter fairing on a standard. Thanks
    78E ... Gone but not forgotten
    2006 Kawasaki Concours....just getting to know it
    I don't think you can mount the cycle sound on a standard. When I had the vetter on my standard, there was NOT room for it. The vetter fit MOST of the bikes of the day, and the XS1100 was the largest at the time. The '78 had a great fairing built by Pacifico, with a STRONG mount system. I would see if you can find one, as in my mind they offer more protection and less wind resistance than the vetter.
    If you want to fix the mount, you can. have a FLAT steel surface to work on, cut the welds so you can lay the mount surface flat once again, and re-weld the mounts.
    • magnum440
      • 64
      • Farmville, NC
      Hello, Isaw a set of plans for a Vetter mount on the XS11 Yahoo group. Here is the link, http://f1.grp.yahoofs.com/v1/cGsXSVV...pt#257,4,Slide 4. You might can paste it in your address bar. If this doesn't work, PM me and I'll see if I can scan them for you. Also I have one that I have not mounted yet and can send you some pics of it if it will help. If you don't have welding capabilities let me know and maybe we can work something out if your not in a big hurry.
      Stacy Clontz Farmville, NC
      1980 XS1100SG
      1971 Maico 400 Square Barrell
      1973 Honda CR250M
      • cywelchjr
        XS-XJ Super Guru(Deceased)
        • 4450
        • Sacramento, CA
        I have a cyclesound on my standard with a vetter fairing (windjammer III) or at least I did before I took it off because the radio doesn't work. I'll probably put it back on when I find a stereo I want to put into it.
        I also have a windjammer ss that was taken off that also had the cyclesound unit on it, but the PO changed to the windjammer III which is black and painted the bike to match (not a happy thing in my mind).
        But the operative thing is that the cyclesound WILL fit if the fairing is at the right height.
        Craig Vetter's website has instructions on how to properly mount vetter fairings, and he covers both height and angle (IE. windshield should be at the same angle as the forks). I don't remember/didn't pay attention to height as I have the right mount, I will be however be paying attention because I have to make a mount so I can put my extra fairing on my XS400G.
        • davidsymons53
          • 197
          • Peterborough, Ontario
          magnum440, I am looking at a vetter fairing for my xs1100sh and I was searching the site for mounting bracket info.
          I would appreciate if you would send me any info you have, plans, pics, etc.
          Thanks David
          1981 XS1100 Special
          Previous Bikes
          1999 Honda Goldwing Aspencade 1500
          1983 Honda Goldwing Aspencade 1100
          1982 Honda CB900c
          1984 Honda vt750 Shadow. My son's bike now.
          1984 Honda vt500 Shadow
            Your looking for a Vetter Mount and I am looking for a Pacifico mount. If only we could help eachother out!
            • SthrnSqrl
              • Jul 2010
              • 77
              • Andover, Ohio
              I have a Windjammer V on my 78 Standard. I am currently using a Vetter Sound setup, so I don't know if it is the same dimensions as the Cycle Sound. I will snap pics tomorrow/today of the mount bracket, and if you want, I can measure the length and width of it.
              http://farm2.static.flickr.com/1278/...01bfdb21_b.jpg
              1978 XS11 Standard -- For Sale or Trade
              4 into 1 (brand?)
              Special Tank (really sucks for size)
              Special Side covers
              Winjammer 5 fairing with Vetter Hard cases
              1979 XS11 Special (has a new home elsewhere)
              1982 Yamaha XV920J Virago - My new daily rider.
              National Cycle Plexi-3
              Saddleman double bucket seat
              custom paint
                FWIW, the Windjammer V uses a different stereo housing than the Windjammer II or III.
                • davidsymons53
                  • 197
                  Thanks SthrnSqrl. Pictures and measurements will be helpful.
                  Here are some pics of the fairing.
                  1981 XS1100 Special
                  Previous Bikes
                  1982 Honda CB900c
                  • TomRodgers
                    • Jun 2008
                    • 492
                    • La Porte Indiana
                    Davids.....
                    I see the problem. you have it mounted on a garbage can...
                    My 81 standard has a windjammer of some model.....with the factory Yamaha wiring plug/plate. It has the square headlight.
                    I have a cyclesound housing on it and everything fits with the guages intact.
                    '81H (my first XS ) "Grey Ghost"
                    4:1 Jardine w/ headerwrap
                    Windjammer(wiring issues)
                    New paint/brakes to come!!
                    '80G FrankenBike (parts bike)
                    '80G to fix "BlackSunshine"
                    Stock Pilots/125 mains
                    Pod filters; 4:1 Kerker??
                    SS Brake lines w/ new M/C's
                    LED Brake Lite
                    Needs paint....
                    • davidsymons53
                      • 197
                      Yes, that's the problem! I have to remove the fairing from the garbage can and install it on my xs1100sh.
                      That brings me to another problem, I have to build a mount for the bike. Any plans, drawings, templates, measurements, pictures, etc., would definitely help me move the fairing from the garbage can to the bike.
                      Here are some pics of the mount for an xs1100.
                      1981 XS1100 Special
                      Previous Bikes
                      1982 Honda CB900c
                        check out craig vetters website there is examples and other things to help make mounts if you dont have them. http://www.craigvetter.com/pages/Vet...de-mounts.html
                          Is that the bracket you are looking for, or the one you have? The one I have on mine is similar, but does not have that angular bracket thing across the middle. Just a flat bar with 2 holes in it that line up with the holes in the front of the XS's frame down-tubes. The 1/2-tube pieces just rest on the front of the down-tubes, and get clamped on with hose clamps. I'm not sure of your horn configuration, but if you have the dual horns, they need to be both mounted inside the 2 front down-tubes to allow the fairing bracket to fit. They can't hang off the side like dumbo ears.
                          • davidsymons53
                            • 197
                            The pictures are from two different eBay sales (one ends Sep 01, 2010 17:44:45 PDT) as brackets for an xs1100.
                            If some other configuration of the bracket would work I would welcome any plans, drawings, templates, measurements, pictures, etc. that would get the fairing attached to my bike.
                            1981 XS1100 Special
                            Previous Bikes
                            1982 Honda CB900c
                              If the prices aren't too high, I'd go for that bracket on ebay. At least you know it was properly welded and not just thrown together. The design looks like it should work.
