grounds
    • 2074
    grounds
    I was looking at a previous thread and was wondering.On my SG there is a ground by the side cover that goes from the frame to the middle drive and that's it.Should there be any more?I would think so, but where else would they be located?When i put the rectifier i bought from Geezer on Saturday, there are 2 grounds that attach to it but should there be any more?Thanks.
  • randy
    • Dec 2003
    • 4521
    Other than the ones you mentioned, there are grounds at each turn signal stalk and at the tail light housing.
    • XSPastor
      • Oct 2007
      • 602
      • Gaithersburg, MD
      The one that goes from the battery to the frame?
      Tim Ripley - Gaithersburg, MD
      23mm float height
      120 main jets
      42.5 pilot jets
      drilled stock airbox with K&N
      Jardine 4 to 1 Exhaust
      spade fusebox
      1st and 2nd gear fix
      • XSPastor
        • Oct 2007
        • 602
        • Gaithersburg, MD
        I was reading a post recently about using an extra ground strap to ground the starter to the ground on the final drive. The goal was better cranking. You can buy the ground straps at MikesXS for pretty cheap.
        23mm float height
        120 main jets
        42.5 pilot jets
        spade fusebox
