I am a new owner of a 1980 XS 1100. It has just about 60,000 miles. I have read many of the forums and have learned tons. But i have had trouble in locating the info i need.
The Problem:
I just brought the bike and only drove it about 5 miles. I went to change the oil and only about 1 1/2 cups of oil come out. I put in new oil and a filter. Then tried to start it. It was kind of hard starting, just turned over a lot. I was able to get it going but it started to smoke out of the left exhaust. At one point it seemed liked a smoke screen from the video game Spy Hunter.
Doing some research on this site i have come down to 2 things.
1-I did not put oil into the oil filter cap. (i did turn it over a lot before starting) SO maybe the oil pump did not pick up any oil.
2- or It sounds like a blew a piston ring- it is not really making any catastrophic sounds, that would make me believe that i blew a piston, just the idea of oil getting past the rings.
__________________________________________________ _______________
I have talked to some friends and they say the white smoke was caused by the carbs needing to be worked on. Not the right fuel/air mixture. Which could be, It was sitting for a long while.
I am going to pull out the engine. My goal is not really to upgrade anything, but i if it is not hard and too advanced i would not mind making some upgrades that are cheap and improve the engine power and reliability in some way.
MY QUESTION
What items do i need to buy to have ready to replace when i pull off the engine? I do not want to have have to wait for any parts from the mail.
On my list so far: I know there is more.
A gasket set and ring set
While the heads are off do i have them machined or not bother?
Is there anything i should be aware of that you might of had problems with or a certain tool that made your life easier in this process?
I am also going to rebuild the carbs. I would like to find out that member's info that he did the work on the carbs (re-jet) and then ran them on his bike. I have seen is ad on ebay and on this site, however i have been unable to find it again.
I have not really done any internal work on bikes before. I did buy the manual on Ebay that they send to your computer. I am thinking it is not the same as the manual in book form. But i am not stupid. A little slooooow at time but not dumb.
Just a side note, I plan to use individual air pods on the carbs and Thinking about straight pipes.
IF you guys are still with me after this long post i would really appreciate any feed back you could give. If you tell me of any more parts please also make sure you tell me where to get them.
I know many have answered questions like this in the past, however please take some time and give me some ideas, even if you cut and paste them. I will read them all.
PS I have had a real problem with my blinkers and brake light.I bought all new after market lights with 2 LCD brake lights. (that i cant get to work) I think it was the wire that came loose from inside left hand side controls. SO i am going to replace it after two soldering blisters, However When i look on Ebay even with some of the 1980 controls they do not have the hazard light switch on the bottom. I do not know if they list the control wrong in the description or if i really do not have to worry about it that switch. The plug-ins look the same, just no switch located on the bottom of the controls.
---Ideas for this would also be very helpful.
If you guys respond and ever drive through Fresno CA, I will buy you a beer. First come-first serve..( i am not loaded you know
Thank you -Will
The Problem:
MY QUESTION
Thank you -Will
