Trickle Charger In Canada
  • Sandy H
    • Sep 2006
    • 118
    • Toronto Ontario Canada
    I have a 82-xj1100.I want to bring in the battery and put it in the basement.
    Anyone have any suggestions of what kind to buy & where to get it?
    Cdn Tire?
    Movin On Down The Line.
    Where Ever You Go.
    There You Are.
    '82'xj1100j Maxim
  • mitch
    • Oct 2002
    • 934
    charger
    Yup CTC will do you want whats called a Battery Tender it will charge when it needs to then shut off. Under 40 bucks at CTC. You can just leave it on mine is in series with my lawnmower battery and my bike battery HTH
    Doug
    Doug Mitchell
    82 XJ1100 sold
    2007 Stratoliner 1900 sold
      Canadian Tire carries a pretty good range of chargers.
      This manual one is about as small as they come both in price and charging capacity. It would be all you need to use every few weeks to keep the charge up over winter.
      Do a bit of googling for "battery tender" for a type of low-capacity charger that has is supposed to turn itself off when the battery has reached its charge level. They look like a good idea, but I'm sure I've heard reports of bad things when these units fail and they end up cooking a battery.
      If I was buying another one, I would go for something a little bigger than either of these options that would have enough capacity to actually charge up a dead battery or do an initial charge on a new battery. Canadian Tire has a manual one or an automatic one
      Places like NAPA and Lordco will also have lots of choice.
      • Axel
        • May 2007
        • 869
        • Renfrew,Ontario
        try this
        I was recommended the 11-1544-4 CTC minder type charger at 1.5 amps . Unfortunaltely it has been discontinued But there still are some on the shelves . My friend gets about 10 years out of a battery using this all winter . He checks the fluid level periodicaly .
        XJ1100K
        Avon rubber
        MikesXS black coils
        Iridium plugs w/ 1k caps
        MikesXS front master
        Loud Horns (Stebel/Fiamm)
        Progressive fork springs
        CIBIE headlight reflector
        YICS Eliminator
        • Axel
          • May 2007
          • 869
          • Renfrew,Ontario
          I just checked my local CTC and they had 2 of 11-1544-4 charger left at $50 . This is half of what the proper charger is at a friendly bike shop . Any charger that charges more than 1.5 amps is killing your battery. And 1 amp is not enough . It takes longer but ...you can leave it in the bike in winter but check levels periodically .
          Since CTC is in the business of selling batteries ,this charger that extends the life is discontinued ...
          P.S. Ken - linky no worky
          XJ1100K
          Avon rubber
          MikesXS black coils
          YICS Eliminator
            "mine is in series with my lawnmower battery and my bike battery"
            Hi Doug,
            if you connect two 12V batteries in series you'd need a 24V charger so I'd bet you have them connected in parallel, right?
            In my experience that works fine so long as both batteries (or like where I used to winter-store my powerboat, a whole rack of batteries) are the near enough the same size. One small bike battery and one large truck battery parallel-connected to the same charger will see the small battery getting seriously over-charged.
            • mitch
              • Oct 2002
              • 934
              Thanks fred
              Ill un hook the lawn mower one then i wasnt aware of that Duh!
              Doug
              Doug Mitchell
              82 XJ1100 sold
              • blue giant
                • Aug 2007
                • 880
                • Ontario, Canada
                Doug
                Now you owe Fred an Alpine for the good advice he just gave you!
                Paul
                1983 XJ1100 Maxim
                1979 XS1100 Standard
                1980 XS1100 Special
                • mitch
                  • Oct 2002
                  • 934
                  Paul
                  Shup you
                  Doug Mitchell
                  82 XJ1100 sold
                  • Sandy H
                    • Sep 2006
                    • 118
                    Trickle charger
                    I got the last onr today at cdn tire thanks
                    Now I just have to figure out how to use it.
                    Where Ever You Go.
                    There You Are.
                    '82'xj1100j Maxim
                      Hi Sandy,
                      Like most things it's easy once you figure it out
                      Hook up the little plug supplied with it. Then you just connect the plugs and plug the charger into the wall socket. Can be left on all the time or just plug in for a 24 hours once week. Watch the fluid level which is a little difficult on the XS with the battery installed. Don't give up yet, still a few rides left if we are lucky.
