The XS1100 u-joint yokes are made out of cast iron. Basically, I didn't like the feel and fit of the drive shaft in the output yoke while doing the 750 final drive mod with a copper bushing as a spacer.
My XS1100 drive shaft could move a full tenth of an inch from side to side with the copper spacer. I cut the output spline tube from a spare XS1100 u-joint assembly to use instead of a copper spacer.
To my dismay, the spacer fit the end of the drive shaft perfectly and no wobble was possible but it would not fit through the swingarm tube up to the yoke!
The swingarm will have to be removed for this mod and now is an exellent time to adjust/grease the swingarm bearings and check the integrity of the rubber u-joint boot anyway.
Obtain a copper bushing for a spacer.
Cut and trim the copper spacer until you find the correct fit for the XS1100 drive shaft to the 750 final drive input coupler.
Cut the output splines from a spare XS1100 u-joint using the copper spacer as a template.
For a solid fit and to use the spacer splines to power the shaft under load, drill two opposing, matching holes in the spacer and the output yoke with a 1/16" drill bit.
Use broken 1/16" drill bit shanks as hardened locator pins to hold the two pieces together and then bond them with JB Weld so the spacer cannot slip off of the cold pins.
The u-joint output yoke can now engage the drive shaft splines almost their entire length.
There is no wobble or any other undesireable movement at all.
Check the fit of the u-joint and drive shaft on the bike before installing the swingarm.
Clean and install the swingarm tube and install the drive shaft.
Measure from the swingarm flange face to the drive shaft gear face to ensure the correct fit in the 750 final drive input coupler splines.
Until I actually bought a 750 final drive, I was wondering about the differences between the XS1100 and XS750 final drive couplers.
For those that are wondering why you can't put the 1100 coupler on a 750/850 final drive, here they are!
Side view, 1100 on left, 750 on right.
Top view, 750 on left, 1100 on right
Bottom view, 750 on left, 1100 on right
Regards,
Scott
Regards,
Scott
