Hey everybody! new to the forum and i figured i'd say hello. i'm helping a friend rebuild a 79 xs11 and the forum has been a great technical help so far. Anyway i figured i'd show you guys the start of the build.. Ok, the first pic is not the actual bike but what it looked like before we started (never took a before pic
).. the rest of the pics are after a few recent additions. So far we've stripped off the fairing and all unnecessary body parts, modified the oil cooler bracket, changed grips, added a headlight we got at a local salvage yard and turn signals from an old project bike i had (that project was rushed and will be redone), removed the air box and added pod filters, rejetted, changed any leaking engine gaskets (a few), modified a rear fender off of a 1996 virago 750 and mounted it with a few custom brackets and choice swear words, then finally figured out how to mount the nice cushy seat off of the same virago. Runs great and looks stock if you didn't know the difference (not to mention strong as hell). Here's what's next on the drawing board:
-rebuild rear brake master cylinder
-Paint and minor body work (Black with either red or white pin striping)
-Front fender change to something paint-able
-change rear signals and redo front headlight and signals
-custom pipes (still debating on design)
-white-wall tires
-new plugs and wires (black with either red or white pin striped wires)
Let me know what you guys think of the work in progress!! Thanks!
Blaze
before:
Right now:
).. the rest of the pics are after a few recent additions. So far we've stripped off the fairing and all unnecessary body parts, modified the oil cooler bracket, changed grips, added a headlight we got at a local salvage yard and turn signals from an old project bike i had (that project was rushed and will be redone), removed the air box and added pod filters, rejetted, changed any leaking engine gaskets (a few), modified a rear fender off of a 1996 virago 750 and mounted it with a few custom brackets and choice swear words, then finally figured out how to mount the nice cushy seat off of the same virago. Runs great and looks stock if you didn't know the difference (not to mention strong as hell). Here's what's next on the drawing board:-rebuild rear brake master cylinder
-white-wall tires
Blaze
before:
Right now:
You gonna lower it in the back or leave it like it is?
