Front Brake Mods
  • omegaxj
    • 104
    • Milford Station, Nova Scotia, Canada
    Front Brake Mods
    Okay, I checked the Modifications threads and could not find an answer to my question. Which is, can I replace my current front brake calipers on my 1978 XS1100 with calipers from an early 1980's Yamaha FJ 1100 or 1200? Will they fit and work? I see that they have a "tall" 2-hole banjo bolt that allowed a second hose to go to the fork (I believe). That bolt could be replaced with one like on the current calipers.
    There are some for sale on Ebay and they should be an improvement over my current ones which are rather weak. And yes I have cleaned them and changed the fluid.
    The FJ's are 2 piston, so they must be better. BTW, there is even a pair of Vmax calipers for sale. They would really stop you fast if they could be used.
    Thanks for any advice you can provide.
    Mark Robertson,
    '84 XJ1100 - SOLD
    '79 XS1100 - SOLD n still going strong
    '07 Bandit 1250S
  • randy
    • Dec 2003
    • 4521
    Mark,
    Have you installed stainless lines? Upgrading your calipers may not give you the braking power you're looking for if you keep the old spongy lines. The original equipment calipers do a fine job with just the stainless line upgrade.
    • omegaxj
      • 104
      Randy, do you have a source for the stainless steel lines? I once tried to get them made for my former XJ but that's a long story...
      Mark Robertson,
      '84 XJ1100 - SOLD
      '07 Bandit 1250S
      • blue giant
        • Aug 2007
        • 880
        • Ontario, Canada
        Try here Mark
        Raymond at
        Rennsport
        3360 Midland Ave , Scarborough, ON, M1V4V7
        phone (416) 291-3953
        Fax (416) 291-3383
        Quoted $24.95 each for 22 inch length, Shipping in Canada $12.00 for a set of 3
        Cheers,
        Paul
        Paul
        1983 XJ1100 Maxim
        1979 XS1100 Standard
        1980 XS1100 Special
        • omegaxj
          • 104
          Thanks Paul, I'll check them out.
          BTW, if Doug owes you a beer, it will be an "Alpine" by Moosehead.
          Mark Robertson,
          '84 XJ1100 - SOLD
          '07 Bandit 1250S
          • Axel
            • May 2007
            • 869
            • Renfrew,Ontario
            I wouldnt
            YOU may want to read a thread describing my experience with the above supplier . I have had to send back lines twice now . Once because the banjo fittings did not swivel and wouldnt fit. Once because two of the lines leaked . BEWARE
            XJ1100K
            Avon rubber
            MikesXS black coils
            Iridium plugs w/ 1k caps
            MikesXS front master
            Loud Horns (Stebel/Fiamm)
            Progressive fork springs
            CIBIE headlight reflector
            YICS Eliminator
            • snowdog51
              • 348
              • st. paul ,mn
              brakes
              buy a modern sport bike mc fast cheap
              or put on a fj fork it's bolt on i'm writing a how to on it should be done in a week or so. bill
              ps all brakes should have stainless lines
              bill hane
              • jankoman
                • Sep 2008
                • 2
                • Mid-Hudson Valley, NY
                Russell Brake Parts
                I just ordered some Russell SS braided brake lines and fittings from denniskirk.com. Do a general search "RUSSELL BRAKE LINE" and sort it from low price to high price. You'll see all the different fittings, etc. I plan on upgrading the front over the winter. I just did my rear brake line. All went well.
                • Hideki
                  • 85
                  • West Hills, CA
                  These bikes front brakes are really good once you install some SS lines. The factory 3 line setup made the front brakes feel spongy, I installed a 2 lines SS setup on my bike and the bike brakes amazingly well now, no more sponginess don't buy new calipers until you install some SS lines first
                  • Axel
                    • May 2007
                    • 869
                    • Renfrew,Ontario
                    Rennsport
                    Although Raymond at Rennsport has been quite accomodating , communication has been sketchy ,emails lost and I finally had to phone to get answers . They will take the lines back or exchange defective ones ( it has happened before) but each time I pay the shipping back to them . So ... by the time its all added up I would have been farther ahead to go elsewhere ,order better lines in colors with bolts and washers .
                    XJ1100K
                    Avon rubber
                    MikesXS black coils
                    YICS Eliminator
                    • randy
                      • Dec 2003
                      • 4521
                      Omegaxj,
                      If you want to duplicate the stock setup here are the dimensions of the lines:
                      Hose #1 M/C to Union 16”
                      Hose #2 Union to Front Caliper 22-3/4"
                      Hose #3 Union to Front Caliper 22-3/4"
                      Hose #4 Rear M/C to Caliper 19"
                      • jjwaller
                        • 242
                        • Gautier, MS
                        S/S Lines
                        Mikes XS has a full set of lines too.
                        http://www.mikesxs.com/
                        Well they used to!
                        Sorry, just a limited supply of made up
                        ones.
                        John
                        '81 CB900C ( 10 Speed)
                        '78 CB750F ( The F)
                        '76 CB400F ( The Elf)
                        New '82 Honda MB5 Ring Ding
                        Then: '76 CB550K
                        '78 CB750F
                        '84 VF1100S
                        And still Looking!
                        • Geezer
                          • May 2003
                          • 2985
                          • Willamina, Oregon 97229
                          For anyone in the NW Oregon area, there's a shop in Portland that will make them up while you wait. It's Oil Filter Service and they do good work at a reasonable price.
                          If you can't afford stainless lines, they have some high pressure conventional lines that are amazing. I did a brake job on an old Honda 4 and the rubber lines from Oil Filter Service were a great improvement over stock.
                          Geezer
                          • jjwaller
                            • 242
                            • Gautier, MS
                            Brake Lines
                            Sorry, I was thinking of Z1 Enterprises,
                            But, they have cut way back on the products offered. Ordered mine from them last year. They no longer offer
                            them.
                            John
                            '78 CB750F ( The F)
                            Then: '76 CB550K
                            '78 CB750F
                            '84 VF1100S
                            And still Looking!
                            • blue giant
                              • Aug 2007
                              • 880
                              • Ontario, Canada
                              Re: I wouldnt
                              http://www.xs11.com/forum/showthread...threadid=18850
                              Hey Alex, Didn't realize you were having issues with them. Is there a specific set for the XJ vs. the XS?
                              Are you trying to do away with the unified brakes?
                              Paul
                              Paul
                              1983 XJ1100 Maxim
                              1980 XS1100 Special
