1st gear slipping(any helps with this)
  • 82maxwis
    • Sep 2008
    • 3
    • milwaukee,wi
    Welcome to the site, first.
    Does it sound and feel like a machine gun, chatter chatter? If so, it's time to pull the pan and do a transmission fix.....
    The instructions can be had by going to the "tech tips" from the MAIN Forum page, not just from here. (xs11.com) There is a VERY good writeup on how to fix 2nd gear. First is the same problem, just a different set of gears.
    • mitch
      • Oct 2002
      • 934
      Give you the gears
      Clutch slipping or jumping out of gear? Bike,year ,model, location. Lots of info and help here if you need it . Welcome to the site these are great bikes but you need to be able to wrench a little on a 30 yr old bike. most here would drop by and help if they could but we need a lil more info
      Good luck
      Doug
      Doug Mitchell
      82 XJ1100 sold
      2007 Stratoliner 1900 sold
      • XSPastor
        • Oct 2007
        • 602
        • Gaithersburg, MD
        His profile says he has an 82 XJ.
        Tim Ripley - Gaithersburg, MD
        23mm float height
        120 main jets
        42.5 pilot jets
        drilled stock airbox with K&N
        Jardine 4 to 1 Exhaust
        spade fusebox
        1st and 2nd gear fix
        • 82maxwis
          • Sep 2008
          • 3
          • milwaukee,wi
          1st gear problem
          Guys Thanks for your help.
          I have looked at the article on 2nd gear problem.
          yes it makes a sound like a machine gun, but dosnt come out of gear.
          what i do is shift into 2nd gear and go from there.
          do you guys recommend grinding the cogs on the gear, so they will mesh together better.?
          any info would be great.
          Thanks
          P.S. i will update my profile.
          • XSPastor
            • Oct 2007
            • 602
            • Gaithersburg, MD
            Yup - that's the fix. The "fingers" from fourth engage those little "ledges" on first. You need the square everything up and then grind them so they pull together by back-cutting the mating surfaces to match just like the tech note shows. You'd better do the 2nd/5th interface while you're in there. Some also switch the thrust washer to the other side of second to allow more engagement in second gear. I did. No problems since.
            23mm float height
            120 main jets
            42.5 pilot jets
            spade fusebox
            • 82maxwis
              • Sep 2008
              • 3
              • milwaukee,wi
              Great
              Thanks for the info, sounds like this will be a winter porject.
