What have I done????
  • Toolmaker Tim
    • 671
    • South Bend, Indiana
    Success!
    Want thru the carbs again looking for clogs. Much garbage on the bottom of the bowls. Looks like I'm going to have to address the rust issue in the tank. Cleaned everything, idle screws weren't broke off thank God. Put in the 45 pilot jets, readjusted the idle mix screws, and was able to adjust the idle down to 1100rpm's. That's a first. Hopped on and found the missing bottom end power! Whoopie! Was able to spin the back tire with not problem, no dumping the clutch or other nonsense. Again a first! Looks like I'll speed up the buying of the new tires. Best of all no more glowing header pipes! Thanks for all the suggestions and help.
    1979XS1100SF
    K&N's and drilled airbox
    Jardine 4in1
    Dunlop Elite 3's
    JBM slide diaphragms
    142.5 main jets
    45 pilot jets
    T.C.'s fusebox & SOFA
    750/850 FD mod.
    XV 920 Needle Mod.
    Venture Cam Chain Tensioner
    • tarzan
      • 1700
      • Chandler,Az.
      Did you put inline filters on it?If you have junk coming in from the tank that will certainly stop most of it.Glad to hear you found the extra power.These things do have power dont they?
      80 SG XS1100
      14 Victory Cross Country
      • Toolmaker Tim
        • 671
        Inline Filters
        Sure do. When I first put the fuel lines in I put in filters. I'm thinking I need better ones. The ones I have are the pancake type.
        1979XS1100SF
        Jardine 4in1
        Dunlop Elite 3's
        142.5 main jets
        45 pilot jets
        750/850 FD mod.
        XV 920 Needle Mod.
