Fork seals again
  • Geezer
    • May 2003
    • 2985
    • Willamina, Oregon 97229
    Fork seals again
    I figured it has been long enough since the last fork seal discussion that I could bring it up again without fear of too many flames.
    I know that the factory seals are best but none of the local dealers have them in stock and the pair I bought before I moved aren't turning up anywhere.
    Anybody have any favorite aftermarket source for fork seals? Mikes XS has seals but I don't know if they're the right size for the 1100.
    Geezer
    fork seals
    I like the Leak Proof brand. They just pop in without a driver and can be removed and put into another set of forks if needed. I've had good results with the Parts Unlimited brand also. The Leak Proof seals are great especially if your fork tubes have a few dings in them.
      • 5073
      Re: fork seals
      Just make sure they are right for your model. They do vary with size.
      • Geezer
        • May 2003
        • 2985
        I'd like to get the ones from MikesXS but I can't find the specs on the XS11 for seals.
        The MikesXS seals are 35 x 48 x 10.5/11 mm.
        Anybody know if these are the right size?
        Geezer
          seal dimensions
          Standard: 37X49X8
          Special: 37X48X10.5
          XS650 seals won't work. HTH
          • Geezer
            • May 2003
            • 2985
            Too bad, the MikesXS seals looked to be the best quality.
            Geezer
            • XSPastor
              • Oct 2007
              • 602
              • Gaithersburg, MD
              Doesn't everything?
              Tim Ripley - Gaithersburg, MD
              23mm float height
              120 main jets
              42.5 pilot jets
              drilled stock airbox with K&N
              Jardine 4 to 1 Exhaust
              spade fusebox
              1st and 2nd gear fix
              • stoked
                • Oct 2007
                • 149
                • Broken Arrow, OK
                Re: fork seals
                wha wha, what is this you speek of? I've heard good and bad things about these but had no idea they were that flexible. I wouldn't mind replacing them often if it was that easy.
                79 XS11 special
                  seals
                  The Leak Proof seals aren't rigid like the OEM type. They just pop right in with no tools. I have them on my Special right now which has dinged up tubes from the PO (vise) . The OEM type seals would only last a few weeks in this particular application, but the Leak Proofs are still goin' strong after 2 years. YMMV. They come in regular and moly. If the tubes are pristine, I'd probably go with the OEM type though, they have a little less stiction.
                  • stoked
                    • Oct 2007
                    • 149
                    • Broken Arrow, OK
                    Re: seals
                    Well that is good info. I have a pair of forks that are in the sort of condition that it sounds like the leak proof seals will be good to try on. Thanks for the info.
                    79 XS11 special
                    • Crazcnuk
                      • Aug 2006
                      • 2980
                      • Hinton, AB, Canada
                      Last ones I used, on my Virago, were from Pyramid in Australia.
                      They haven't given me any problems.
                      http://cgi.ebay.com/Yamaha-XS1100-19...713.m153.l1262
                      '05 ST1300
                      • Geezer
                        • May 2003
                        • 2985
                        I still haven't gotten my shipment from Parts'N More but wouldn't you know it, 3 days after I place my order for new seals, I found the pair of Factory Yamaha seals I had.
                        The real pisser is that they were in a box that was right smack in the middle of my garage and not even that well hidden.
                        I managed to build up one set of forks from the screwed set on the bike and a set off a parts bike. With a little luck I can have it finished in time for the last couple of dry days of the year...
                        Geezer
