I have been working on my '78 std. for about 3 months now. I got it running (first time in many years) about a month and a half ago, thanks to this forum's help. I bought a new fuel tank (no rust), rebuilt the carbs, new plugs, new Mike's XS coils, new fuel lines, in-line filters, new K&N air filter, new battery.
I had to rebuild my brakes before I could take it out and ride and I now have them done. Now, when I start it, it's only running on 2 cylinders. 3 and 4 are cold or barely warm. I have removed the carbs four times now, cleaned them, checked the float heights, etc. I have not found anything in the carbs, no broken tips, etc.
I have carb sticks and a colortune, but I don't know how to synch if cylinder 3 isn't firing. Right now it's bread tie synched. Same with the colortune, if the cylinders aren't firing, not sure what to do. I have spark and fuel. If I switch the plugs, no change. If I switch the wires, no change. Leads me to think it's carb related, since 1 and 2 run fine with the wires and plugs from 3 and 4. I'm stuck. Pilot jet screws are 1 1/4 turns out.
I went to check for a broken pick up coil wire, but was suprised to see the vacuum advance line plugged with a screw and not connected. PO must have disconnected.
I used K&L carb kits to rebuild the carbs and I know there are issues with those. But with 1 and 2 are running fine, I'm doubtful it's strictly the jets.
I REALLY wanted to ride this bike before the snow flies! I thought I was almost there. Any advice on what to do???? Anybody want to buy a colortune and carb sticks cheap?
