Need more electrical know how for rear turn signals
  • Korr
    • Jul 2008
    • 293
    • Torrance, CA
    Ok i just removed that bar that has the two rear turn signals mounted to the license plate. I realized that there is only one wire per turn signal. The single filament bulbs i bought have two wires. One hot and one ground wire. There is only one wire per turn signal sticking out of the rear fender. There should be two wires right?
    1978 XS1100E Standard
    Tkat Fork Brace
    On Hold
    TopCat S.O.F.A. + Fuse Block
    Mike's XS Pod FIlters
  • Ivan
    • Jul 2008
    • 2524
    • Hutchinson KS
    If you look, you will find that the stock ones ground to the frame, and thus, do not have a second wire
    Ich habe dich nicht gefragt.
    • prometheus578
      XS-XJ Super Guru (RESIGNED)
      • Aug 2004
      • 4012
      • Olympia , Wa.
      New signals:
      One wire hot.
      Take the second one... and if you want to be cheap about it, back out a nearby bolt, wrap the wire around it and then retighten for the ground. (Might want to smear a little black RTV over it when done to help prevent corrosion on the wire.)
      • Korr
        • Jul 2008
        • 293
        • Torrance, CA
        oh ok. i will do that. thnx guys
        Tkat Fork Brace
        On Hold
        • Korr
          • Jul 2008
          • 293
          • Torrance, CA
          it works! thanks again guys!!
          Tkat Fork Brace
          On Hold
