Idling Problem
    carb sync-er
    Cheap ones are about $60. Good ones $100+. Longer fuel lines should not be a problem unless you kink them.
    • al_ngl
      • Aug 2008
      • 52
      • Lafayette, Indiana
      Yeah I'll probably borrow a synch from someone, kinda short on cash right now. I'll probably just get new fuel line since it's probably original. I usually get braided fuel line, so that shouldn't kink.
      • mro
        • 4276
        • Hayward, California
        Crossing the fuel lines not only makes it easy to route em w/o kinking but also makes it easy to install in-line fuel filters.
        Single spec of debre stuck on a float valve will make that carb leak
        mro
        BTW, I synck the carbs, then adjust the pilots, then re-synck.
        • ClarkGriswald
          • Aug 2008
          • 256
          • Bloomingdale, MI
          I thought you said dont cross the streams?
          XS1100 F/G (79 Bike/80 Motor)
          Grab a tetanus shot and jump on!!!
