Ok so I just got an 850 kicker to put on my 1100 and noticed some "strangeness" when I was playing with it. Keep in mind I've never had anything besides a single quad that was kick start so my experience is limited!
1. After I kick the lever stays "down" and I have to manualy rotate it back "up". Is this normal or is that spring behind the side cover on wrong?
If its not normal can someone point me to a picture or description of how that spring should be, because I swear I checked it (meaning looked at it and thought "yeah that looks right" because I wasn't sure how it was supposed to be.) when I did the 2nd gear fix.
2. The kicker only works with the clutch lever out. Is this common on bikes? On my quad I can start it "in gear" by holding the clutch in while kicking. On the XS if I hold the clutch in there is no resistance on the kicker. Just wondering if that is how it should be.
