bugger - what to check first??
  • SiP
    • Aug 2006
    • 438
    • Medicine Hat, Canada
    Went for a good blast with my buddy about three weeks back then went on vacation so she's not been ridden since. Thought she was running a bit rough when I put her away but put it down to the heat.
    Started her up to move her out of the garage and she's running rougher than a bag of nails. Idles not bad, not smooth like I she has but OK however as soon as you open the throttle she bangs and pops and stalled a couple of times.
    So..... what do I do first?
    Si Parker
    '81 XS1100H
    Tkat brace, new coils/wires/plugs, refurbed carbs (thanks 81 xsproject), recon'd top end, windshield (thanks dpotter58), resprayed tank and panels, 4-1 exhaust, sweet xs pod filters, in line fuel filters, progressive springs, thick hand grips, jumped headlight relay.
    • 8930
    bangs and pops
    It sounds like all 4 carbs aren't getting fuel. I'd try opening each bowl drain and see if they have fuel. You can also tap on each bowl with a ratchet handle in case of a stuck float. Also, try some Seafoam.
    • ClarkGriswald
      • Aug 2008
      • 256
      • Bloomingdale, MI
      Just a thought before ya take stuff apart, might wanna try tapping on each of the float bowls with a wooden handle of something or plastic screwdriver handle.. mabye ya got a float/needle sticking. Worth a shot.
      XS1100 F/G (79 Bike/80 Motor)
      Grab a tetanus shot and jump on!!!
      • prometheus578
        XS-XJ Super Guru (RESIGNED)
        • Aug 2004
        • 4012
        • Olympia , Wa.
        I need a buddy like that. Does she have a sister?
        This may sound stupid... same thing happened to me.
        Try putting some fuel in the tank.
        (You're on reserve.. bike is slanted to the left, as is the fuel in the tank, right side starves)
        • tarzan
          • 1700
          • Chandler,Az.
          Maybe even a kinked fuel line?
          80 SG XS1100
          14 Victory Cross Country
          • SiP
            • Aug 2006
            • 438
            Tapped away like a demon and checked the fuel lines - no change
            Si Parker
            '81 XS1100H
            • chrisso
              • Jun 2008
              • 182
              • Sydney Australia
              Plugs??
              80 XS11 Standard Australia
              • wa407mpp
                • Jul 2007
                • 717
                water
                Fastmover
                lion". SHL
                78 XS1100e
                • Cbass182
                  • 51
                  • Mount Pleasant, MI
                  Exact same thing happened to me, one of the vacuum lines that goes from the carb boots (If I remember right) to the petcock was torn on the end, so only two carbs were getting fuel...thing ran like crap, backfired, popped, stalled, you name it...it would run and drive...but barely.
                  I cut the end of the line off going to the petcock where it tore, popped it back on the petcock, replaced two spark plugs, and away i went...
                  -Chris-
                  1971 CB750 K1 (Painted 96-98 honda blue, currently reassembling from total teardown)
                  1979 XS1100F Dark Blue (almost done...seized bolts makin me PO'd!)
                  1979 CX500C (project/parts...bad stator...)
                  1981 CX500C (currently the bike i ride)
                  • chrisso
                    • Jun 2008
                    • 182
                    • Sydney Australia
                    Mone was running really rough a while back-drained float bowls...lots of rust in the fuel, coming from badly rusting tank; fixed it with Kreem Tank sealant( which I highly recommend)
                    • SiP
                      • Aug 2006
                      • 438
                      Ok, pulled the plugs pic attached and also checked compression,
                      Carbs were very recently professionally rebuilt by a good guy from this forum, tank has been stripped acid bathed and sealed.
                      Didin't check spark yet though.
                      Compression:
                      1: 80psi
                      2: 95psi
                      3: 90psi
                      4: 80psi
                      Si Parker
                      '81 XS1100H
                      • SiP
                        • Aug 2006
                        • 438
                        by the way plug from cyl 1 on left.
                        Si Parker
                        '81 XS1100H
                          • 8930
                          compression
                          Sip, those readings look a little low. Did you hold the throttle wide open when testing? Otherwise, not enough air can get into the cylinders for a proper reading. Compression should be @ 142 psi.
                          • SiP
                            • Aug 2006
                            • 438
                            no and thank you - I'll do that again.
                            Si Parker
                            '81 XS1100H
                            • prometheus578
                              • Aug 2004
                              • 4012
                              • Olympia , Wa.
                              First off, you need new plugs!
                              That could be half your problem.
                              Then need to figure out why they fouled.
                              Then, go bother your neighbor and borrow HIS compression guage.
                              Your reading are consistant, but too low.
                              Your guage could be off.(I don't want to discuss the alternative, which would be valves.. but that wouldn't explain the fouled plugs)
