My new rear tire arrived earlier than expected so I had it mounted and balanced today. Yay! Matched Metzlers!
While I had the rear wheel off of course I checked the drive splines and coupler grease even though I'd just cleaned and greased them, mmm... (checks odometer) a little less than three thousand miles ago. I had painted the splines with Honda 60 moly grease, then hand-packed everything with high temp moly wheel bearing grease and gave it a couple of good shots with a grease gun after final assembly.
There was almost no grease in the coupler, on the drive shaft splines or in the lower swing arm tube around the drive shaft. Does the grease crawl out of the coupling and sashay up the swing arm tube?
I didn't take the drive shaft out this time but unless half a can of high temp moly grease completely vaporized I suspect it's piled up on the back side of that plate at the bottom end of the swing arm tube behind the lower drive shaft splines.
Is it supposed to do that?
I thought, apparently incorrectly, that the plate inside of the lower end of the swing arm would keep the grease in the bottom end of the swing arm tube. Should I find or make a seal to fit inside the swing arm tube and over the drive shaft to keep the grease where it's needed instead of gradually filling the upper part of the swing arm tube?
Should I stop worrying about it and just keep adding more grease until it starts to come out the top of the swing arm tube and begins to fill the rubber boot at the u-joint?
Regards,
Scott
Regards,
Scott
