Engine Stop Switch
  • MrOzz
    • Aug 2008
    • 782
    • Massachusetts
    Engine Stop Switch
    My switch on my 80 xs1100 special no longer switches. Thankfully its stuck in run.
    I was going to order the following from Mikes XS
    http://www.mikesxs.net/mikesxs-chass...ategory_id=1.4
    Part #24-2060
    I just want to make sure this will be a direct replacment for whats on mine. (plug and play)
    Any info will be appreciated.
    Ozz
    1980 XS 1100SG
    Dyna 3 Ohm Hi Output Coils
    Pod Filters
    DynoJet Kit
    T.C.'s Fuse Block
    V-Max Auto CCT
  • red bandit
    • 970
    • central michigan
    I would take it apart, clean it and use some dielectric grease first. The left side needs the plug off the 11 soldered on the new switch. Don't know about right hand switch.
    79 SF parts bike.
    • MrOzz
      • Aug 2008
      • 782
      • Massachusetts
      I have taken apart the switch to clean it. The problem is the housing for the switch is broken and beyond repair due to PO.
      But thanks anyway.
      Ozz
      1980 XS 1100SG
      Pod Filters
      DynoJet Kit
      T.C.'s Fuse Block
      V-Max Auto CCT
