"I gots da blues..."
Ok... the blue wire, as you can figger, is for the running lights for both front bulbs.
The dark green and the chocolate one are for the turn signals.
The front signals ground through where they mount to the forks.
Now then... with your aftermarket lights...
I can remember with a double filament bulb, which filament is for running lights and which for turn signal operation... so here's what ya do.
Hook up the original lights again.
Turn on the ignition and see which filament lights up.
Then, connect the wires to the new lights, and switch them around till the same filament lights up on them.
Oh wait... damn, forgot that these are LEDS.
Really won't matter much then. Either they have circuitry to make them flasher brighter when signalling, or they only use some LEDs for running, and when signalling, they light up the rest.
Both wires are hot wires... one for running and the other for flashing. The turn signal unit should ground where it mounts.
Hard for me to really say without actually looking at the lights.
on my flashers is the ground the black wire & on the xs the chocolate & dark green?
They just stay on and then turn off if i signal. I know for sure the wiring in the headlight is connected correctly. All the same symptoms are there with the stock lights except that they do not give that medium glow on the turn signal indicator on dash. I tried switching the wires around for the stock lights and the aftermarket ones, but no luck. Could i have fried something? popped a fuse or burnt the flasher relay?
and, without thinking, I grabbed the LE and instantly gave myself 2nd degree burns to one of my fingers and my thumb. The LE had already begun to melt through the plastic fender!
. Had the hard bags been re-attached, the seat put back on and, the bike covered up, the bike could have possibly, conceivably and, realistically, been burnt to a crisp
