i have the rear end all torn apart for the first time - now i have yet more questions.
1. the final drive unit has a slight leak - nothing major. The book says if it is leaking to take it in for service. is this necessary?
2. as i said, so far this is the farthest apart i've had the bike. i want to be certain everything is good from the engine back. i am to the point of sliding the rubber boot back to remove the four bolts which secure the drive shaft to the middle gear housing. here is where i have stopped as i'm not sure how to get the bolts off as the driveshaft turns freely. my first thought was to put it in gear but was leery of this as i don't want to damage anything. my question here is how do i proceed and if it is even necessary?
3. the rear shocks seem to be leaking. there is a thin film of oil/dirt on the inner side. is there any way to tell if these need replaced? if so, where would i find the parts? new? old?
4. will i gain anything by removing the rear swing arm?
i apologize again for all of the questions. thanks in advance for any help offered.
Cory
Cory
