Has anyone tried these? If so, how was the quality and was it hard to fit them? ebay slide diaphragms
Tim Ripley - Gaithersburg, MD 1981 XS1100 Special "Spoiled Rotten" Just sold - currently bikeless!!
23mm float height
120 main jets
42.5 pilot jets
drilled stock airbox with K&N
Jardine 4 to 1 Exhaust
spade fusebox
1st and 2nd gear fix
Yeah, but this is 99 bucks for all 4 diaphragms! Curious to hear if anyone out there has tried these...
23mm float height
120 main jets
42.5 pilot jets
spade fusebox
you are the first person I have every seen even mention, much less provide a link, to this diaphram deal since I have been reading this forum. That's pretty cool. You didn't say what's wrong with yours or if you are even thinkin' about gettin' new ones? Yours perforated ... shrunk ... wrong color .... something else?
Methinks thee needs to give 'em a try though, 'specially if yours are trashed out and let us know how they work .... do you pry 'em apart, heat 'em, freeze 'em or what to get that round plastic block out? Anyway ... the price is pretty fair compared to the ones at PNM.
79F Stone stocker and former daily driver, sold May '10 now converting for N.O. to cafe style 79SF eventually dismantled for parts 79F Bought almost new in 80, sold for a house 79F The Ernie bike sold to a Navy dude summer 08 79SF Squared-off Special, Vetter/Bates tour pkg., Mikes XS coils, G rear fender and tail light. Sold June 09
How do you get the old ones apart? It looked like the plastic retainer was molded in place on the assembly. I didn't dare try and dis assemble them for fear of having to spend $250 on replacements.
According to the illustrated instruction sheet that they sent at my request, you cut the upper ring off with a utility knife, remove the old diaphragm, put the new diaphragm on and superglue the ring back on, clamping it with a nylon tie-wrap until it dries. They claim, they hold up just fine, but I wanted to hear if anyone here had tried them. My current diaphragms are ok - not great. I'm just looking down the road for when I have to replace them. 25 bucks a piece seems reasonable when you see what others are charging for the slide/diphragm assembly. Even at 64 bucks each (which is the cheapest I've seen) you're talking about 256 bucks for four.
23mm float height
120 main jets
42.5 pilot jets
spade fusebox
The price on their web site is $89.00. I suppose the 99 price is to offset ebay listing fees. Remember, these WILL NOT fit the 78-79 carbs. The 78-79 are not available at this time.
put something smooooth betwen your legs, XS eleven
79 F (Blueballs)
79 SF (Redbutt)
81 LH (organ donor)
79 XS 650S (gone to MC heaven)
76 CB 750 (gone to MC heaven)
rover has spoken
I'm confused, the ones on Parts N More say this - "Fits XS1100G/H/LG/LH/SG/SH (81-82)"
G, SG and LG are 1980 and it looks like they come with the slide also. I've put super glue on rubber before and it cracks when the rubber flexes, it could cause a leak.
I tried using superglue
on the diaghrams after it was
recommended by a yammy mechanic.
DONT ever use it, it dries hard, and it started
melting/breaking down the rubber.
pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
I had an old diaphragm lying around. With those 'replacements' in mind, I tried taking it apart. The metal slide is flared out to hold the upper plastic ring on. If I recall correctly, I ended up breaking the ring to get it off. While I haven't actually done the replacement, I would highly recommend trying something else.
