Simple clutch problem
  • Tusler
    • Jul 2008
    • 79
    • Hemet, CA
    Hi,
    My clutch is slipping on my 1980 midnight special. When I try to accelerate hard like on a freeway on-ramp I have to modulate the throttle or it will slip every time. I am using the proper motorcycle oil.
    SOoo, does anyone have a extra clutch metal plate I can buy from them and put in the 4th spot in the stack?
    Or is that a universal size/part used on many bikes I can get at the local motorsport store?
    Thanks
    1980 Xs1100 MNS Sold for $1800
    2004 Roadstar XV1700
    45 to 50 MPG
    Ask Jesus for Forgiveness before it is too late!
  • psycoreefer
    • Feb 2008
    • 1557
    • Minden, NV
    I've got what you need, send me a PM with where you want it shipped.
    You can also get new stiffer springs if you wanted to.
    1979 xs1100 Special -
    My Bike:
    [link is broken]
    • egleaves
      • May 2007
      • 441
      • Sacramento
      Heavy duty springs made my clutch slippage almost disappear.
      Cleaning my burnt steel plates with a random orbital sander loaded with 60 grit eliminated it completely.
      I know this, because Tyler knows this.
      1980 SG
      3J6 003509
      Kerker 4-1 (sans baffles)
      Fuse Block Upgrade
      Mike's XS Green Coils
      Pods w/Homemade Velocity Stacks
      • TADracer
        • 1417
        • Kenner, Louisiana USA
        I say get the extra steel plate, just in case but, if you are going to take the cover off and go into the clutch, change the springs too. They are relatively cheap (around $20-$25) and are so easy to replace. Check your friction plate thicknesses too.
        Mike Giroir
        79 XS-1100 Special
        • XSPastor
          • Oct 2007
          • 602
          • Gaithersburg, MD
          You can get a set of springs for under 10 bucks. You should definitely replace them when you're in there. They cleared up my clutch slipping.
          EBC Clutch Springs
          Tim Ripley - Gaithersburg, MD
          23mm float height
          120 main jets
          42.5 pilot jets
          drilled stock airbox with K&N
          Jardine 4 to 1 Exhaust
          spade fusebox
          1st and 2nd gear fix
          • thewiz
            • Oct 2006
            • 1115
            • Wilksboro, NC
            You can also ...
            shim the springs with a washer underneath ... kinda' like a valve spring on an automotive cyl head. I have a steel too .... 951.443.9708
            80G Mini-bagger
            Past XS11s
            • Tusler
              • Jul 2008
              • 79
              • Hemet, CA
              Got Springs & Plate on the way
              Thanks a lot guys!
              This site is great.
              I have the springs and the plate on the way thanks to you all.
              I have a speedo and tach on the way too.
              I have put about 600 miles on it in the last month for reliability testing. After I get the clutch setup - I think I'll head up Hwy395 and do some camping.
              Thanks
              Bernie
              45 to 50 MPG
              • webbcraft2150
                • Sep 2002
                • 1605
                • AUSTIN.TX
                My 80g did the same thing at 63k on the clock. I bought new plates and springs. ALL the old plates measured well withing specs. The springs were junk though. I went ahead and replaced everything anyway. The springs are alot cheaper and easier to install. Be careful when reinstalling the "star".
                  Hey Tusler,
                  Funny, but nobody first asked if you are sure that you've done the adjustment at the ENGINE/CLUTCH cover side properly, AND then adjusted the slack at the lever, AND then also made sure that the clutch cable wasn't binding...that the inner cable is sliding easily within the sheath?!
                  Glad you have the parts you need coming, but just wanted to mention the above.
                  WIZ, with the extra steel, shimming the springs isn't needed. Also have heard of a few folks who broke their star plate by putting the washers on the outside of the springs next to the plate, instead of under them next to the clutch basket!
                  Tusler, hopefully you've seen the tech tip about the extra steel, it shows about the star plate and how it can get broken!
                  • thewiz
                    • Oct 2006
                    • 1115
                    • Wilksboro, NC
                    Thx, TC, I should have been more specific
                    I realize that both are not necessary ... reason I offered both ideas is that Tusler lives close enough to buzz over and pick up a steel, had he wanted to or I coulda' dropped one off. Planedick is close too and has the correct washers. Unfortunately, I just didn't respond to this thread soon enough. Can't imagine him (or me) putting the shims on the wrong side of the springs though .... but stranger things have happened, I guess .... I've certainly made my share of bonehead moves before too.
                    80G Mini-bagger
                    Past XS11s
                    • Tusler
                      • Jul 2008
                      • 79
                      • Hemet, CA
                      Hi,
                      Yep I 've seen the tech tip about installing the star so it does not break.
                      The adjustments at both ends are good. I have plenty of adjustment left which to me indicates minimal wear. I think you guys hit the nail on the head with the springs. The bike only has 22k on it but simply the age of the springs has made them weak. I'm pretty sure the plate and springs will cure the slip.
                      If I have any problem I'll phone-The Wiz!
                      I get this thing right I'll probably call anyway. I've been wanting to see them bikes you got.
                      45 to 50 MPG
