Oil light
  • Sandy H
    • Sep 2006
    • 118
    • Toronto Ontario Canada
    Oil light
    I have recntly had the oil changed.
    since then when i start up the bike(1982 xj 1100 maxum)
    the oil light keeps flashing for about 2 min. then it goed off.
    the oil level is fine.
    any ideas
    Movin On Down The Line.
    Where Ever You Go.
    There You Are.
    '82'xj1100j Maxim
  • blue giant
    • Aug 2007
    • 880
    • Ontario, Canada
    Sandy,
    Did you change the filter as well. I find my XJ takes a bit more regardless of a filter change or not. Typically I half to put 3-3/4 liters w/o filter change and the full 4 liters with a filter change, other wise the light comes on and off intermittently. XJ's use an oil level sensor as opposed to the XS's pressure switch.
    HTH
    Paul
    Paul
    1983 XJ1100 Maxim
    1979 XS1100 Standard
    1980 XS1100 Special
    • Sandy H
      • Sep 2006
      • 118
      oil light
      Yes there was not enough oil in it.
      It took a full 4
      thx
      Where Ever You Go.
      There You Are.
      '82'xj1100j Maxim
