Hi first time forum submitter:
I'm picking up a 1980 XS 1100 which the owner tells me has slipped a cam chain. Here is the theory on the problem as I've been told. The cam / timing chain slipped a tooth while he was riding it last September. It would not idle and had no power. he believes it is due to the nylon chain guide wearing down. he's been told that they become brittle and are known to deteriorate with age. So, the bike may need to have the chain guide replaced and while in there replace the chain itself.
I asked a local shop for a quote on the job and I was told it would cost $1150 for parts and labor, bit steep.
Would like to see if anyone in the forum has experience in this and can give me a low down on the job, how to make it more manageable if I attempt to do it. I'm mechanically inclined and would attempt this with the correct manual, but I figured why not see if there were ways others have found to help either ease the cost of repair or ease how to do the repair.
Would appreciate your help. Thanks.
PS: Other than the cam chain issue, Bike is clean and sweet, that the biggest reason I'm considering it....if I can fix the problem nothing else is wrong with the bike, owner has moved on to a newer model and would just like his garage freed up.
Johann
Johann
![Smilie](https://xs11.club/core/images/smilies/smile.png)
