Front wheel feels tight, wont spin freely
  • digitalsam
    • Aug 2008
    • 208
    • Carlsbad, NM
    Thank you all for the help with the front brake pads. Next issue with my 80 Special is that the front wheel doesn't spin freely like a bike tire does.
    TopCatGr58 mentioned that I may have bent the speedometer gear or the drive prongs, etc...
    I want to start riding, and need to know what to do to diagnose the issue and how to fix it.
    Sam Christensen
    The Chronicles of my Rebuild http://xs1100rebuild.blogspot.com
    If you are leading and no one is following, maybe your just taking a walk.
    Currently bikeless. Sold my 1980 XS1100 Special
  • randy
    • Dec 2003
    • 4521
    If you think it's the speedo drive prongs, the only way to diagnose it is to remove the wheel, pull the speedo drive and see.
    Also make sure your calipers are free to pivot on the mounting bolt, and the pads move freely on their mounting pins.
      I would check the spacing of the right fork tube in relation to the rotor on that side. You can adjust that by loosening the axle pinch bolt on the right tube, and the fork can be moved in or out as needed to align the rotor in the grove on te tube where the caliper sits. Take the right caliper off, and then see how freely it spins. The left side is fixed, so I doubt that side is the problem.
      • planedick
        • Mar 2005
        • 2068
        • Yorba Linda, California
        In order
        Be sure when putting wheel on that you tighten the axle nut first and the pinch bolts on the head of the axle last and for best handling you should have the fork brace loose and the tripple tree clamps loose at this time and tighten all from the bottom up.
        Drilled airbox
        Tkat fork brace
        Hardly mufflers
        late model carbs
        Newer style fuses
        Oil pressure guage
        Custom security system
        Stainless braid brake lines
