Easy way to see oil level
  • Espiritus
    • Jun 2008
    • 45
    • Southern Indiana
    Hey, all. I finally got tired of trying to squint to see where the oil level was on the bike. I have this sniffty LCD flashlight and the end of it is exactly the diameter of the oil cap. So, I took off the cap, put the end of the light against the crankcase shining down into the crankcase, and, presto, could easily see the oil level through the little window.
    Thought I would share this. This might be one of those common sense things that everyone knows but I am a slow learner!
    Cam
  • ross
    • Dec 2006
    • 542
    • see signature...
    lighting issues....
    hey there Espiritus....is a very good idea, but if you go to your local dealership, you can order a stock yahama lighting kit that solves that problem.....2h7-385965.....cost about $4.00......easily installs thru the oil fill hole....hooks up to the fuse box with 2 wires.......hmmmm....should i tell her???.....Espiritus, i'm just kidding you...very good idea though....makes very good sense......have not had an issue with reading the oil level as i can clearly see the sight window and 1/2 hour on the center stand settles it all down anyway....unless it is too full...oops!!!!.....i usually measure the oil i put into the motor and make sure i stop short and fill to proper levels.....just my 2 cents...talk 2 ya later.....ross
    rebel devil
    1979 xs 1100f standard
    authenic historical vehicle
    42°36'23.52"N, 82°52'44.78"W
    "I'M IN MY HAPPY PLACE"
    "i got 14 jobs mon....you only got 1 job....you lazy bones mon"
    "if you don't wrench on it, get behind me satan!"
    '96 venture cct.....installed!
    stainless, braided, pvc coated brake lines
    i can translate...deustch, nederlands, 汉语, 漢語, français, ελληνικά, italiano, 한국어, português, русско, español and most importantly, 日本語....
    • mro
      • Oct 2005
      • 4276
      • Hayward, California
      I used to have to shine a light in my G's hole
      Sounds like your sight glass be a little dirty?
      Next time you have to pull the cover off for clutch work can clean the sight glass. Will then be able to see the oils color thru the glass as well as level.
      mro
      • LoHo
        • Sep 2002
        • 1342
        • Fresno, CA
        ...and if you are careful not to disturb the bike, you can get a cool rainbow effect as the light shines through the gas leaking into the case from the crapped-out petcocks...
        • Ivan
          • Jul 2008
          • 2524
          • Hutchinson KS
          Is there really truly a lighting kit for the inside of the crankcase?
          Ich habe dich nicht gefragt.
          • mro
            • Oct 2005
            • 4276
            Are you familiar with a saying attributed to W. C. Fields?
            mro
            • ClarkGriswald
              • Aug 2008
              • 256
              • Bloomingdale, MI
              I thought P.T. Barnum said that?
              XS1100 F/G (79 Bike/80 Motor)
              Grab a tetanus shot and jump on!!!
              • ross
                • Dec 2006
                • 542
                • see signature...
                crankcase lighting assembly.....
                hey there folks...after this kind of response, the price just went up to $5.00 per unit......talk 2 ya later.....ross
                rebel devil
                • ClarkGriswald
                  • Aug 2008
                  • 256
                  • Bloomingdale, MI
                  Ill just put glow in the dark stuff in my oil.. helps to see it dripping that way at night.
                    • 7766
                    Were I USED to work, if you got too close to the "beam", EVERYTHING would glow in the dark!!
                      Another thing to throw onto the dash
                      Hi Cam,
                      now you've done it. I too have a small diameter LED flashlight and after reading your brilliant thought I will have to keep it on the sidecar dash along with the telescoping mirror so I can check the oil level in the dark. The flashlight will also help me find the filler plug when I drop it trying to thread it back in it's hole.
                      Thanks.
                      • Shappers
                        • Sep 2006
                        • 158
                        • Helsinki, Finland
                        If your sight glass is getting opaque due to it's age, then next time you pull the outer cover off to work on the clutch just replace it.
                        It simply pushes out (to the inside) and a new one costs peanuts (I paid €6).
                        If the sight glass is just dirty, I would lean the bike on it's side and get the Q-Tips in there!
                        '84 Sport
                        • mro
                          • Oct 2005
                          • 4276
                          There is a lot of room under the cover, would not be hard to install something like a fiber optic cable "light" there if one was so inclined. Would not run a LED or incandescent light tho, one spark at the wrong time inside the crank case ....
                          mro
                          BTW, PT had said “There's a sucker born every minute" which one may construe as a derogatory remark and I would never deride or make fun of anyone here.
                          WC Fields was known to say “go away kid, you bother me”
                          • Ivan
                            • Jul 2008
                            • 2524
                            • Hutchinson KS
                            Well,
                            I may be a sucker, but I had seriously considered making some sort of illuminating device specifically for this purpose. I would have gladly spent 4$, or even 5$ (since the price went up). Now I must rely on my own ingenuity. That can be scary.
                            I was thinking about machining the fill cap to accept a LED and affix it with some translucent epoxy. A single wire to the accessory terminal, grounding through the case would be all that is needed.
                            Good or bad idea?
                            • randy
                              • Dec 2003
                              • 4521
                              Ivan, the heat would destroy it.
                              While we're on the subject of W.C. Fields, one of my favorite lines:
                              "Who put orange juice in my orange juice"?
                              and one of his more infamous ones:
                              "I love children, especially deep fried"
