Hello, I'm looking for a picture of the mount point on the carbs for the manifold. I have the mount that is on the manifold, I need to see where it mount to the carbs. Thanks
Fuel Manifold Mount
Your post is a little cryptic, Magnum440. The carbs slide into the holders/manifolds, and are held in place with clamps on the outside of the holders. What year/model bike do you have/ Welcome to the group, by the way!
Hi...my name is Mike, and I'm a lane-splitter.
'80 XS1100SG (mine)
'87 CMX450C Rebel (daughter's first bike) -
I've got all that. Where does it mount? The bracket on the actual spider has to mount somewhere. It has a hole for an 8mm screw according to the parts diagram. I just don't see anywhere for it to mount.Stacy Clontz Farmville, NC
1980 XS1100SG
1971 Maico 400 Square Barrell
1973 Honda CR250MComment
It mounts to the front right srew in No 1 carb where the crome cover mounts to the top of the carb
Trapper81 SH (SHotgun Special)
110 mains
idle jets 2.5 turns
floats at 24mm
You live, You learn, then Die and Forget it allComment
Sorry Trapper,
But yes, there IS a bracket that it mounts to similar to the throttle cable bracket. The bracket is held in place by 2 of the carb top screws, and sticks out forward of the carbs, and THAT is what the Octy attaches to! You can see it by following the Link in the LINKS forum to the Official Yamaha Onlne Parts Fiche site!
T.C.T. C. Gresham
Holy cow MRO!?!? Only thing I can see in the pics is the one month "Limited" warranty on the battery... with something fuzzy in the forground?!? lol..
Boy that company really stands behind their batteries though, don't they? lol
OK, I see the bracket. That's the one I need. Now, who has one or is easily fabricated? Is there a certain angle it should be? I finally found it on the 1100F fiche. Mine is an SG model.Stacy Clontz Farmville, NC
1980 XS1100SG
Hey Magnum,
Several folks have removed/bypassed their OCTY, and so there should be plenty of these brackets laying around! You could post a thread in the PARTS WANTED Forum, and I'm pretty sure you'll get an offer to send one to you for shipping costs only! There is a nut welded to the end, that a large head philips screw goes into. No special angle needed, SO...you could get some peice of bracket at your local LOWES/HomeDepot, and IF you have a grinder, could cut and shape it to fit around the carb top, and just use a nut/bolt combo!?
T.C.T. C. Gresham
Thanks for the replies. I'll try making one now that I have an idea where it mounts. I can use the cable one for a pattern. You say that alot of people scrap the spider, is there a reason?Stacy Clontz Farmville, NC
1980 XS1100SG
