APE Cone Filters
  • bakenath
    • 30
    • Midvale, UT
    APE Cone Filters
    Which ones fit my stock XJ11 carbs....PART # 005-121 or PART # 005-122.
    PART # 005-122 says they fit a 34mm carb which is the size of the carbs according to XS11.com's 82 XJ11 model specification page.
    I want to order ASAP cause I already have the airbox off and I dont want to change jets and put it back on.
    Thanks to all.
    SLC, UT
  • bakenath
    • 30
    • Midvale, UT
    APE Cone Filters
    Sorry here is a link so you dont have to google APE's Website.
      Inside diameter of the carb throat is 34mm, but the outside diameter of the bell... the one you need... for the XJ is 54mm.
      APE also has an oval shaped filter for the same price that has more surface area and helps fill the hole left by the absent filter box.... Just my opinion. Last time I looked for mine, they weren't actually listed on the website. They had them in stock, but I had to call them.
      • bakenath
        • 30
        • Midvale, UT
        Thanx trbig. I think I read a post from you on these filters. It sounds like they did well on your XJ. Ill call them on Monday. Looks like Ill be fixing a leaking petcock until then.
          Just a word of warning... don't use a high pressure washer at the car wash to wash them. It kind of shifts the filter material around a bit and opens holes in it a bit... Ideal would be the dishwasher if you won't get in trouble!! lol.
          Just make sure you synch your carbs afterwards.. it will change things. I went up one size on the mains.... but not sure if I actually needed it or not.
