I've managed to get the majority of the bike together and now I'm to the carbs. I have a Maxim but it's using carbs from an 80 or 81 XS. I managed to get the bike going a few times starting it with ether and that's apparently the only way to get it started. when i get it started, it takes a little work and warm up to let it finally idle on it's own. it idles right at 1k but when it's warmed up it'll hover around 1.5k. all cylinders seems to be firing except #2. it's warm but not hot like the others. i checked and it has a strong spark and is getting gas.
when i go to throttle, it takes a little jiggling to get the RPM's up but it can reach redline. it also "pops" on the throttle down. my guess it's #2. it also blows smoke whenever the popping is made. it just idled with intermittent throttling for a good 10 minutes but died and now it won't start. i had a box fan blowing at full speed to get some circulation going. i haven't caught it but i think it also pops through the carbs. lean? i checked all the plugs and they're saying a little rich except for #2. #2 is wierd, it's half white and half a little black/gray. i guess #2 works whenever the mains kick in. i plugged the vac spout on both the carb and boot for #2 since i wasn't using the octy.
i've cleaned the carbs numerous time, making sure all the orifices are clear. i blew them out with cleaner and ran my carb wire tool through them. took some small wire to the tubes that run down into the bowl that lead up to the choke. they all seemed good.
the carb has 115 mains and the slow jets are unplugged. i bought plugs and tried running it with them installed and nothing could get it going (well, ehter but it could only run on the ether and anywhere above 4K when gas could get into the mains). i checked and rechecked the float height. i'm just stumped on this outcome.
thanks
thanks
