Dawn found me looking in disgust at a puddle of gas underneath the bike that had formed overnight .... can't write what I said, but I'm sure some of you will understand.
Gas leaking was caused by me leaving the front screws loose on the fuel tap I had just rebuilt. My bad. Another quart of gas in the crankcase ... geez, if there were a carbuertor in there, my problems would be solved
I hardly think the oil companies will even notice that I change the oil about every week. What's my three quarts in the overall scheme of things, anyway?
When I pulled the plugs, i was astonished that they all, for the very first time since I've been playin with this motor, were clean and the proper color. So I have been fixin' some things, needles in the center slot was the big thing .... but I ain't done yet.
Still will not pull much past 5500rpm. Feels like its starving. These are the first set of cv carbs I've messed with so I'm payin' the price of learning the nuances of them ... but ... when I re set the needle clips, I noticed that the diaphrams didn't really nest in the circular groove in the carb body very well at all. It looked a hair smaller in diameter ... like it had shrunk ...even the tabs fell short of their little half moon homes.
I thought perhaps that carefully putting the caps on might seal up the rubber .... but now I wonder? I have searched for info on diaphrams and not yet seen a pic .... but ... shouldn't the diaphrams nest easily and fully in the grove? AND could I use some from a spare set of carbs as long as they looked good? If the diaphrams weren't lifting the slides, could that be robbing upper rpm power?
I hardly think the oil companies will even notice that I change the oil about every week. What's my three quarts in the overall scheme of things, anyway?When I pulled the plugs, i was astonished that they all, for the very first time since I've been playin with this motor, were clean and the proper color. So I have been fixin' some things, needles in the center slot was the big thing .... but I ain't done yet.
.... hard to justify the tariff on new ones.
