What to replace.
  • area51child
    • Apr 2006
    • 3
    • Cedar Falls, Iowa
    What to replace.
    I replaced the battery this season, used the old hardware and had a bad connection, which I summarily tightened and didn't worry about until next time it was loose.
    Apparently a bad connection leads to frying the electrical system, eh? Replaced the regulator/rectifier and now she runs, but doesn't charge (checked with multimeter, and no tach or headlight), I assume the alternator needs replaced too.
    Anyone else have some experience or expertise with this? What else may need replaced?
    - Thanks.
    (This would be my first post )
    80 LG MNS
    • 8930
    Clean the connections from the alternator, which are located behind the fuse box. This is a common problem with the charging system on these bikes.
    • mro
      • 4276
      • Hayward, California
      It should not be a problem....as it should be anticipated that a 26 to 30 year old machine just might have a corroded electrical connection or two.
      Should be in the tec tips which most don't seem to read and if it's not in there think I've mentioned it a few times as well as you and about a zillion others
      mro
      • redbone
        • Oct 2007
        • 244
        • Waynesboro pa
        mro is rite
        unfortunately ....yes there is corrosion on these machines, especiallly if ever stored outside.....even for a sshort time. take apart EVERY electrical plug and connection and apply some sort of NO-OXIDANT type of paste. get a small paint brush for the tite spots. yes...it is a pain in the ass, but sometimes a bad electrical connection will keep you from moving. nothing sucks more than trying to find it whille parked along a road someplace.. yes, i have been there.
        testing 1-2-3
        1980 1100 mns
