I recently (last weekend) did a carb sync and color tune to my 79 XS11 special. I have a studder "bbbbbbbbb" at almost every RPM range while accelerating, except arround 3,500-4,500.
What I've done:
I started with a carb teardown (very thourough cleaning)and rebuild .
After finally getting the %$#@&* octypus reconected she ran great from 1/4 throttle to wide open but didnt have the quick throttle response I know shes capable of.
I traveled to a fellow XSers to do a proper sync and color tune(thanks again Ross).
During the return trip home I had great idle and low RPM response but serious studder at RPM over 4K. Now I'm scratching my head.
During the return trip my clutch cable snapped so I replaced it. When I took the first ride with the new cable it felt like the clutch was slipping so I made an adjustment. OK... still studdering. What the #$%^.
I pulledthe plugs and discovered 1 and 2 are black as night 3 and 4 are the way they should look. So, 4 new plugs and she seems better but I still have the studder "bbbbbbb" when I accelerate.
O-yea I replaced all fuel lines with new and made sue to follow the routing diagram.
Is it possible my clutch is in need of serious repair or is it more likely that i need to colortune with the new plugs in, OR is it likely that my $%^&#@* octypus is not working properly.
Please help, I'm not sure what to check next. Thanks for any and all help.
What I've done:
