motor problems
  • abetterday
    • Mar 2008
    • 11
    • canton ga
    motor problems
    I have a problem with my engine losing power when you first start off like its running on 2 cylinders but after the RPM gets to 2500 it takes off. Here is what I have done to correct the problem:
    1.I have had the carbs sinked
    2.I have had the wire on my points replaced because of brakage
    3. Changed Fuel
    4. Changed Plugs
    Not sure what else to do?
    Do you think there might be a pin hole in one of the sides?
    Please can some one help?
    For Abetterday
    For a Betterday
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    which 2 cylinders?
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
    • blue giant
      • Aug 2007
      • 880
      • Ontario, Canada
      Hi,
      Couple of dumb questions from me but here goes, Have you cleaned the carbs especially the pilot circuits? If there is any dirt, crud, varnish or old gas residue it will never run well in the low range.
      Have you cleaned, replaced or properly gapped the spark plugs?
      Have you tested the ignition coils as per the manual.
      And last but not least have you checked and cleaned all the connections for the TCI and ignition coils and have you freshened up the high tension lead connections at the plug caps?
      All simple stuff but can create havoc with the way you bike runs.
      Cheers,
      Paul
      Paul
      1983 XJ1100 Maxim
      1979 XS1100 Standard
      1980 XS1100 Special
      • abetterday
        • Mar 2008
        • 11
        • canton ga
        motor trouble
        Cleaned carbs before I had them sinked. Not sure of coils Replaced the plugs with new ones, seemed to help a little. Checked the wires at the the TCI and replaced one of them. I took the spark plug caps off and re-set them back on again
        For a Betterday
        • abetterday
          • Mar 2008
          • 11
          • canton ga
          It sounds like the 3 or 4 cylinder
          For a Betterday
            Spritz the pipes with water and you can tell which ones are hot... and not.
            • blue giant
              • Aug 2007
              • 880
              • Ontario, Canada
              Not sure if you mean 3 and 4, or 3 or 4.
              As you may know carbs 1 and 2 are fed from one pet cock and carbs 3 and 4 are fed from the other. one ignition coil feeds cylinders 1 and 4 and the other feeds 2 and 3.
              That might help you narrow the problem to fuel or ignition related.
              Paul
              1983 XJ1100 Maxim
              1980 XS1100 Special
                • 7828
                We need the year and model of the bike! If it's a '78 through '81, it is PROBABLY the pick-up coil wires. I've found the front coil to be the usual problem. Do a search from the MAIN forum page to see the "fix".
                  Hey, Ray, that's a great way to narrow it down! How come I never thought of that?
                  • mason79
                    • Mar 2006
                    • 1359
                    • los angeles, ca
                    ray was there in 78
                    History
                    85 Yamaha FJ 1100
                    79 yamaha xs1100f
                    03 honda cbr 600 f4
                    91 yamaha fzr 600
                    84 yamaha fj 1100
                    82 yamaha seca 750
                    87 yamaha fazer
                    86 yamaha maxim x
                    82 yamaha vision
                    78 yamaha rd 400
                    • prometheus578
                      XS-XJ Super Guru (RESIGNED)
                      • Aug 2004
                      • 4012
                      • Olympia , Wa.
                      " I love pickin' on Ray..."
                      Agree with TRBIG
                      (I do that once in a while... only when he posts before I do)
                      Get a spray bottle and hit the pipes at idle. Sounds like a plugged pilot circuit in one o' the carbs. Whoever doesn't sizzle like the rest of the pipes has the bad carb.
                      • mason79
                        • Mar 2006
                        • 1359
                        • los angeles, ca
                        i put my hands on the pipes to see which warms first
                        and which stays cold,
                        so i know way before it even gets hot enough, and able to shut the motor and start looking,
                        my last problem was (3 times)paper element fuel filters that clog
                        when it dries, as the fuel in the lines drain and when i first start the motor would starve out the carbs, since it is now parked on the side stand, #4 and #3 (carbs) got it worse.
                        now i use wire mesh and the prob has gone away
                        History
                        85 Yamaha FJ 1100
                        79 yamaha xs1100f
                        03 honda cbr 600 f4
                        91 yamaha fzr 600
                        84 yamaha fj 1100
                        82 yamaha seca 750
                        87 yamaha fazer
                        86 yamaha maxim x
                        82 yamaha vision
                        78 yamaha rd 400
                        • Winterhawk
                          • Jun 2004
                          • 684
                          • Missouri
                          This might be the problem. I Never knew mine had this setup.
                          • 81xsproject
                            • 3185
                            • Fortuna, CA
                            Now, now, you know what he meant by 'points'. The one thing that I would say, is that for the pickup coil wires and the carbs, don't rule them out just because you had a go at them once. Some folks end up cleaning carbs as many as three times.
                            '81 XS1100 SH
                            Sep. 12th 2015
                            RIP
                            • psycoreefer
                              • Feb 2008
                              • 1557
                              • Minden, NV
                              Many of us WISH we only had to go into the carbs three times. I'm on my 10,000th carb removal or something. At least it seems that way.
                              1979 xs1100 Special -
                              My Bike:
                              [link is broken]
