Front wobble?
  • Del Tysdal
    • 73
    • Glyndon MN USA
    Front wobble?
    When I slow down to under 30 mph there seems to be a wobble in the front. I look down to see the tire and there is no side to side wobble. Both front and rear tires are less than 2000 miles. The wobble is noticeable but not a problem. Any ideas? Thanks
  • Rhumba
    • 82
    • Vancouver, WA
    The first thing I would check are steering head bearings.
    Then all the triple tree clamp bolts.
    Then the axle clamp bolt.
    And the front wheel bearings.
    More help is on the way I'm sure.
    Ride Safe!
    Never scratch your head with a nail gun!
    1982 XJ1100
    • Del Tysdal
      • 73
      • Glyndon MN USA
      Thanks
      Thanks. Will try the suggestions.
        This can happen if the steering head bearings are too tight. Prop up the front end and see how easily the forks flop from side to side. It should take only a gentle nudge to get the forks to move over from a centre position. If you have to push, even lightly, to get the forks over, it is too tight.
        • Del Tysdal
          • 73
          • Glyndon MN USA
          forks to tight
          So how do I loosen the forks if they are to tight? Thanks.
            The top nut in this photo is a lock nut.
            The bottom nut is the adjustment. Being sure the adjusting nut does not move, back off the lock nut. Loosen (or tighten if needed) the adjusting nut about 1/4" or so at a time and recheck. When it feels right, bring the lock nut back down to hold the adjustment.
            It may help to use a scratch awl to mark a reference line for the adjusting nut before you start moving anything.
              Loosen the top center nut on the triple tree, loosen the two outside clamp bolts, the center clamp bolt, and remove the top triple tree. You then use a "spanner" wrench to loosen the TOP or lock nut in the center, and then loosen the bottom nut just a little.
              • Del Tysdal
                • 73
                • Glyndon MN USA
                Reply
                Thank you very much.
                  You'll need two of them
                  Hi Del,
                  spanner wrenches, that is.
                  Google McMaster-Carr
                  McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
                  scroll down to hand tools, click on spanner & drum wrenches.
                  You'll have to hold the lower nut at the correct place with one of them as you tighten the upper nut against it with the other.
                  • psycoreefer
                    • Feb 2008
                    • 1557
                    • Minden, NV
                    fancy wrenches...
                    don't you all know that the only tool you need is a hammer?
                    I've had good luck adjusting mine using a hammer and appropriately sized punch. I don't own a spanner wrench. May not be as "precise" as a wrench but It got me close enough. Just use the punch to get against the flats and then tap with the hammer to tighten or loosen.
                    1979 xs1100 Special -
                    My Bike:
                    [link is broken]
                    • Del Tysdal
                      • 73
                      • Glyndon MN USA
                      Thanks, again
                      Yes, thanks again.
