Wondering about engine noise
  • Korr
    • Jul 2008
    • 293
    • Torrance, CA
    Hi guys i just picked her up about 2 weeks ago. I am happy to say that i will no longer need to own another bike. This IS the one and only for me now after going through 4 bikes in 2 years. I know some engine noise is normal for these old gals, but i just can't ignore the rattling sound. It sounds REALLY bad on the video, but in person it sounds half as loud. I have been reading up on the cam chain tightening and adjusting valve clearances and i will be doing those as soon as i get the manuel from PO this Tuesday. just wondering if you guys are able to recognize and see what would be causing that sound. thnx guys
    here is the youtube link
    1978 XS1100E Standard
    Tkat Fork Brace
    On Hold
    TopCat S.O.F.A. + Fuse Block
    Mike's XS Pod FIlters
  • prometheus578
    XS-XJ Super Guru (RESIGNED)
    • Aug 2004
    • 4012
    • Olympia , Wa.
    "Maybe if you put some oil in the thing...!"
    Well... provided that there is nothing else wrong, I'd agree and say it's the cam chain.
    (My ears aren't as good as they used to be... which makes sense, as the rest of me is in pretty poor shape, too)
    Never hurts to run a compression check and to check the valve clearances. No noise makers there... it's just good to know that everything's ok.
    Yeah, wait for the manual. Instructions are pretty straight forward.
    Only caution is, do not over-tighten the bolt that locks the tensioner plunger in place after you've made the adjustment.
    Some people have stripped these... the adjustment then won't hold.
    Any questions, just ask.
    • TADracer
      • May 2006
      • 1417
      • Kenner, Louisiana USA
      Sounds kind of like cam chain to me also. If you have an engine stethoscope you may be able to pinpoint the noise alot better. If you do not have one you can use a piece of wooden dowel and place it against your ear. Sometimes these motors make noises that sound like it is coming from 'here' when it is actually from 'there'. How many miles do you have on the clock?
      Mike Giroir
      79 XS-1100 Special
        • 8668
        noise
        The clattering noise when it was idling a bit rough sounds like the HY-VO chain slack jerking the tranny gears around. This sound is normal especially on a higher mileage motor. If the engine is idling smoothly, that chain won't jerk back and forth. That high pitched scraping noise is a bit louder than normal. That's the cam noise these motors make amplified by the cooling fins on the head.
        • dbeardslee
          • Nov 2007
          • 4385
          • Maineville, OH
          I agree - sounds like the cam chain. I adjust mine every couple hundred miles. Out of synch carbs can make them sound like they're about to fall apart, also.
          • Korr
            • Jul 2008
            • 293
            • Torrance, CA
            ok i just did the cam chain and it way better! it also no longer sounds like something is spinning loose in there when i rev it really quick and release. yeah the loudness from the video is purely extra loud because of the camera. the camera is some how making it sound twice as loud and scratchy.
            Tkat Fork Brace
            On Hold
              • 8668
              noise
              Glad it was simple as that.
                • 5051
                You are lucky it didn't slip the chain!
                • Korr
                  • Jul 2008
                  • 293
                  • Torrance, CA
                  maybe i spoke too soon hahaha! I now notice a constant metal to metal rubbing sound. I only notice this with my helmet on and i'm sitting on it with the engine on. It gets louder as i speed up. Kinda sounds like sandpaper on metal. It wasn't there before the cam chain adjustment. It sounds like something spinning and rubbing. Any ideas guys? I hope it's normal for old bikes hahaha!!
                  Tkat Fork Brace
                  On Hold
                  • dbeardslee
                    • Nov 2007
                    • 4385
                    • Maineville, OH
                    Korr - I'd use TADracer's stethoscope idea to pinpoint where the noise is coming from. Just about any autoparts store will have them, and they're pretty inexpensive. I like them better than using a dowel or a piece of metal as they block out the ambient noise and isolate the sounds better.
                    • Korr
                      • Jul 2008
                      • 293
                      • Torrance, CA
                      Ok i'll go pick one up at kragen friday and try to figure out where it's coming from.
                      Tkat Fork Brace
                      On Hold
                      • Brasco18
                        • Jun 2008
                        • 84
                        • Duluth, MN
                        I recently did a camchain adjustment and it made a huge difference in the sound of my engine. I do still hear a metal noise but these bikes are old; that is just how they are made. Everything is mechanical, no electronics. they are going to sound noisy. As long as there isn't debris in your oil...
                        Stock '79 xs1100 Standard
                        • Korr
                          • Jul 2008
                          • 293
                          • Torrance, CA
                          Po did say it needed an oil change. I'll have to do that friday also. He says he used synthetic in it. I was reading about how full synthetic might cause clutch slippage. If i use a half snthetic would 20-50 be ok and who makes it? Would preferr a brand that could be bought at a cycle gear or a yamaha dealership. thnx
                          Tkat Fork Brace
                          On Hold
                          • dbeardslee
                            • Nov 2007
                            • 4385
                            • Maineville, OH
                            Korr - I run 15w40 dino in mine. I tried 20w50 but it was harder to start cold. I think most would recommend against synthetics as most have friction modifiers that can cause the wet clutch to slip. When you look at the sae circle, make sure the lower half of the circle doesn't have any writing in it. I run the cheapest dino I can find and change it regularly.
                              • 5051
                              Castrol makes a synthetic blend. I have had good luck with it.
                              Originally posted by Korr
                              snip
