Exhaust Busted?
  • egleaves
    • May 2007
    • 441
    • Sacramento
    Exhaust Busted?
    Over the weekend SWMBO and I went for a nice long ride to enjoy the beautiful weather we were having. At some point on the way home I noticed the bike sounded different and after twisting the throttle a few times I could tell that the exhaust had changed tone. At the same time, though, I noticed a pretty big increase in power over 5K RPM. When I got home and looked in the muffler (it's a Kerker megaphone style) I saw that the perforated baffle has separated itself from the rest of the muffler and is laying loose inside. I was able to re-seat the baffle in the end of the muffler, but a short ride caused it to dislodge again. The bike's a little bit louder now (actually sounds kinda wicked) and has a little more power so I'm wondering if I should just leave it be? Anyone else ever have this happen to them? Is my muffler busted? I haven't had time to take it off yet for further inspection.
    I know this, because Tyler knows this.
    1980 SG
    3J6 003509
    Kerker 4-1 (sans baffles)
    Fuse Block Upgrade
    Mike's XS Green Coils
    Pods w/Homemade Velocity Stacks
    • 8798
    kerker
    Yep, thats happened to me with a Kerker. If you want it to stay in, take a pliars and slightly bend the rear part of the tube so it stays tight in the end cap. Tap it in with a hammer. If the end cap is also loose, put a sheet metal screw or two thru the canister to hold it in place. I run mine with the baffle out sometimes, and yes it does sound good, but it will cut back on the low end grunt.
    • XSPastor
      • Oct 2007
      • 602
      • Gaithersburg, MD
      You could leave it be if the noise is manageable, but keep an eye on the plugs. You may run leaner without the back pressure from the baffle.
      Tim Ripley - Gaithersburg, MD
      23mm float height
      120 main jets
      42.5 pilot jets
      drilled stock airbox with K&N
      Jardine 4 to 1 Exhaust
      spade fusebox
      1st and 2nd gear fix
      • egleaves
        • May 2007
        • 441
        • Sacramento
        Well, this could be a blessing in disguise then. I've been running a little rich lately, so maybe this will balance out my mix.
        1980 SG
        3J6 003509
        Fuse Block Upgrade
        • XSPastor
          • Oct 2007
          • 602
          • Gaithersburg, MD
          If you've made no changes and have only been running rich lately, you may need to clean/change you air filter(s).
          23mm float height
          120 main jets
          42.5 pilot jets
          spade fusebox
