Main Fuse
  • Ivan
    • Jul 2008
    • 2524
    • Hutchinson KS
    Main Fuse
    What amperage is the main fuse that is not in the fuse block, but in front of the battery on the left side?
    81 special, if that makes a difference
    Ich habe dich nicht gefragt.
  • XSPastor
    • Oct 2007
    • 602
    • Gaithersburg, MD
    30 amp
    Tim Ripley - Gaithersburg, MD
    23mm float height
    120 main jets
    42.5 pilot jets
    drilled stock airbox with K&N
    Jardine 4 to 1 Exhaust
    spade fusebox
    1st and 2nd gear fix
    • Ivan
      • Jul 2008
      • 2524
      • Hutchinson KS
      Well, that explains why the 10 amp one the PO put in was fried in short order.
      • XSPastor
        • Oct 2007
        • 602
        • Gaithersburg, MD
        Sure does. You may want to check the others too.
        Tail light 10A
        Head Light 10A
        Turn Signal 20A
        Ignition 10A
        23mm float height
        120 main jets
        42.5 pilot jets
        spade fusebox
        • Ivan
          • Jul 2008
          • 2524
          • Hutchinson KS
          the others are a work in progress. Mine definitely needs a fuse block repair.
          Thanks for the list. I will put it to good use.
          • powerram50
            • 92
            • portland,oregon
            ya so does my 81.
            81 SH for 300 bucks,work in progress.
            87 dodge d-50,35's,lockers fr&rr,fun.
            87 dodge d-50,35's,open diffs,wifes.
            89 dodge spirit,low 17's 1/4mile w/o turbo.
