Standard tank on special frame?
  • drunner
    • Jul 2008
    • 6
    • Minnesota
    I've got a 1979 Special, but found a nice $20 standard tank I can buy off someone (and no, I will not reveal my source at this time.)
    The standard has more than the 3.6 gallons I can get out of mine before I go to reserves, right? I was going to paint it anyway, and I like the look of the standard better. So I was wondering what issues there might be with this. Anyone know? I am not sure of the year of the tank.
  • Dennyz
    • 1151
    • Olympia, Washington
    The tank will bolt on. You will need Standard petcocks. You will have to reroute your fuel lines and vacuum lines because the functionality of the octopus (remove it) is built into the petcocks.
    Your Special seat will be snug up against the back of the tank and a little tough to install the seat.
    You will also need to run an overflow vent hose from the tank to below the frame.
    DZ
    Vyger, 'F'
    "The Special", 'SF'
    '08 FJR1300
    • geniusloerts
      • Jul 2007
      • 420
      • fayetteville, Arkansas
      I am putting a standard tank on mine see!!!
      1979 XS1100 SF "Black Goblin"
      -Pod Filters
      -4-1 pipe
      -larger jets for carbs
      1982 XJ1100 "Black Sheep"
      • Brent
        • 959
        yes to alll of the above. I also had to remove yellow reflectors from the sides of the special frame (near the bottom front of the tank.) Also the petcocks can cost MUCH more than the tank you are considering.
        Brent in GA
        • egsols
          • Jan 2006
          • 1090
          • Barrie, Ontario, Canada
          I take that the special petcocks will not bolt into the standard tanks?
          Ernie
          • thewiz
            • Oct 2006
            • 1115
            • Wilksboro, NC
            "I take that the special petcocks will not bolt into the standard tanks?"
            Nope. Not without an adapter plate of some sort. While certain adapters are available at MikesXS, I'm uncertain about one that would convert the two types of XS ones.
            80G Mini-bagger
            Past XS11s
            • egsols
              • Jan 2006
              • 1090
              Thanks, wiz
              Ernie
              • drunner
                • Jul 2008
                • 6
                • Minnesota
                well, dang, someone bought it. I should have bought it when I had the forst offer, and the cash. My fault for delaying. But now I know something.
                One thing I was surprised at - went to my local Yami dealer today and they have plenty of original parts for good prices. Nice.
                • dbeardslee
                  • 4385
                  • Maineville, OH
                  Genius - sweet lookin' tank. Did you primer it yourself, or did it come that way?
                  • egsols
                    • Jan 2006
                    • 1090
                    Standard tank on ebay, item no. 140253009351, starting 49.99 buy now 70.00
                    Ernie
                    • geniusloerts
                      • Jul 2007
                      • 420
                      it came in the original maroon i stripped it, bead blasted it, filled the emblems and little dents that there were and primered....
                      -Pod Filters
                      -4-1 pipe
                      • thewiz
                        • Oct 2006
                        • 1115
                        • Wilksboro, NC
                        Hey, Genious ...
                        Just curoius, did you remove the emblem brakets before ya filled 'em in?
                        80G Mini-bagger
                        Past XS11s
                        • geniusloerts
                          • Jul 2007
                          • 420
                          no, i fugured it would be a goog ancor for the filler, so i packed it in all around and behind to insure there was no air.
                          -Pod Filters
                          -4-1 pipe
                            Hi Dennyz,
                            your Special seat may have been "a little tough" to install with a Standard tank but mine would not engage the front hold-down tongue at all. I had to trim 5/8" off the front of it before it would engage properly.
