Hello all, nice to meet you! I was reading this forum for some time. Didn't know if my 78 XS11 was going to make it. Now it is alive so I had to register to resolve few minor issues. First of all, it was in a very bad shape when I got it (as a gift!). The problem areas were carburators and front forks. Carburators were not repairable (believe me, I have some experience in restoring carbs). But I did try anyway with no luck. Then I tried to find a set on ebay and was outbid 2 times. Finally got the carbs off ebay for a 79 kawasaki 1000 and respaced them for my XS11. Had to cut/weld 2 links, but now they work just fine. The forks were so rusty so there was no point in restoring them. So I got a clean set off ebay too. Sealed the gas tank with por15, replaced intake manifolds with new ones, removed the head, cleaned pistons... I just love the process. Thet it started. But only 3 cylinders were working. Compression test did not show anything wrong but when crancing without spark plugs I got a nice stream of oil coming fron #2 spark plug hole. So, I disassembled the top part again, removed the head and the cylinder block, replaced rings and valve steem seals and readjusted valve clearances. These procedure gave the effect I was hoping for - Idle is good, throtle response is good, power is good.
Now, I need to do some exterior work. So here are the questions - maybe someoneone can help.
1. Speedometer does not work - the old pickup is brocken. What is better - try to find new (used) pickup, which to the dade I was not able to find. Or try to fit an electronic speedometer. Then there are questions about the sensor type, place etc. Or maybe it is better to forget about it? 5000 rpm = 80 mph. What else should I need to know
2. I want to try to find/match the old paint (macho maroon). What should I do - take it to the shop for painting or try to match it myself?
3. How do I repair the cracked seat? Or is it better to take it to a professional? Then where to? I am in SoCal.
4. Vaccuum advance is very noisy. When the throttle is closed it clicks too much. Is it supposed to work like this?
I am probably going to need more help - I just don't remember now. Thank you for reading
BTW, who can tell what is wrong with this picture of 78 XS1100E? And I an not talking about a disassembled engine.
