Dim headlight when headlight fuse is removed
    My headlight was working normally, but it also came on - with severely reduced brightness - when the headlight fuse was removed.
    Okay, that is not supposed to happen.
    After a few false starts (like stripping out the entire wiring harness and creating a detailed, full-color, wiring schematic) a simple continuity test of the headlight relay uncovered a short circuit between the White wire terminal from the stator and the Blue/Black wire terminal to the Reserve Lighting Unit.
    The latching diode was shorted internally. It was, effectively, just a fancy wire with a decorative ceramic bead in it. The relay cover was also full of corrosion:
    I replaced the diode and
    now the headlight does not come on if I remove its fuse.
    Regards,
    Scott
  • boyat68
    • Oct 2007
    • 358
    • Virginia
    3Phase:
    Good job, nice to document your fix for others to use and show that it can be done.
      Thanks, boyat!
      It's yet another successfully completed step in a ongoing troubleshooting process that's been exacerbated and complicated by the age of the machine and its components.
      I have considered just lighting a rag in the gas tank as the days go by and problems appear and disappear like some absurd combination of a Camus story and a extremely expensive and time consuming game of Whack-A-Mole.
      Then I go out for a ride... when I get back, the grin won't leave my face and I just resume troubleshooting with my handy phone-cam to document things when and if I find them.
      Regards,
      Scott
