After pulling the tensioner on my bike and examining the guides, I would bet that a lot of the looseness in many older bikes is from the guides being worn. On mine the grooves in the plastic slides are nearly 1/8" deep. I suspect that there is plenty of life left in the guides, as it looks like they aren't even halfway through.
I suspect this, along with a mildly worn chain, caused full travel at the timing chain tensioner and leave the chain a bit loose.
Would there be anything wrong with milling .080" off the face of the tensioner where it mates to the cylinder block? Doing this would increase the throw of the tensioner considerably and help compensate for the worn guides.
Ivan
Ivan
Otherwise you could cause it to jump teeth and would then need a head/valve job soon!
